Dyno Results Dyno pictures, videos and dyno results.
LSJ-T S252ET On Pump Gas
Old Oct 16, 2014 | 11:53 AM
Bluelightning's Avatar
Got Bewst?
Well after a long summer with my car but I finally got it on the rollers! There's still room to grow in this tune. I went just from 11.6-12.0 afr and picked up 18whp. But kinda ran out of time to play around any further. Made 379whp/307wtq. Was hoping for a little more in the end but all and all not too disappointed considering I'm on pump gas. The long and short of my set up is:
- Gen 3 motor with DI pistons
- ZZP turbo kit with an S252ET turbo
- Ported head
- ZZP S2 cams
- ZZP 3" Catless downpipe
- ZZP 3" Exhaust
- 22 psi
- 94 pump gas. No meth
Old Oct 16, 2014 | 12:03 PM
InfraRedline's Avatar
There's the thread! Not bad for 22-23 lbs on pump. Can't wait to bring some E85 up next week and play around
It's crazy that it picked up that power just from going to that little bit richer AFR from being in the shop to the AFR we run it at on the street. That's a huge gain for a small change. Makes you wonder if the DI piston design has anything to do with it, or if the gains from leaning out an actual DI car are strictly from the port of the direct injection.
Overall, I think you hit your original goal from last year of wanting to make the same power or slightly more with pump gas on less boost than your TVS race gas/meth setup. Next time it will be time to turn up the boost a bit!
Also, the car was completely remote tuned.
Old Oct 16, 2014 | 12:05 PM
Staged07SS's Avatar
Administrator
Administrator
Very nice numbers man!!
jonathan923's Avatar
i think thats a very low reading dyno. good numbers none the less but ive seen stock motor gt30r set ups on 93 @ 23psi put down 400whp flat. either way different dynos etc but seems a but low still
Old Oct 16, 2014 | 12:09 PM
Also, should be noted. The car has a ramp to 19* advance and boost tapers to 20-21 lbs up top. A healthy amount of timing, I think its time for more turbo
Edit: Looked through it and peak boost was 22.2 PSI.
Old Oct 16, 2014 | 12:20 PM
yellowsupercharged06's Avatar
E85 !!!!!!! i dont wana hear im either lol Buy a oil tank and fill it with E85
Dat Curve thoo
Old Oct 16, 2014 | 12:32 PM
LNFTX's Avatar
Thats a pretty good looking graph congrats
How much more is left in the 252 what kind of psi can you push it to
Old Oct 16, 2014 | 12:35 PM
Got Bewst?
It very well could be. I had a run in with a 2011 GT 500 with full bolt ons, pulled down and tuned last night. By the top of 3rd he had me by 3 lengths which I throught wasn't too shabby lol.
Old Oct 16, 2014 | 12:36 PM
We pushed it to 26 lbs on 91 but were having diminishing returns with the limited advance we could run causing scary high EGT's. Haven't tried more on 94 yet, but it should have no problem being efficient at 25-26 lbs, but will still taper to 20 up top. I'm bringing him the gift of E85 next weekend to mix in so we will have some fun with some more boost then He's only at 78% duty cycle, so we have some room to throw some mixed E and boost at it for shenanigans.
Got Bewst?
Ummm Id say 26-27psi would be the most I would run out of it. Next year is meth injection so thatll help a lot. Up in the air if I'm gonna roll a bigger turbo or not.
Old Oct 16, 2014 | 12:40 PM
The **** is this ****?^
Old Oct 16, 2014 | 12:44 PM
Got Bewst?
just gotta find dat turbo without much out of pocket. You know the song and dance america lol.
Old Oct 16, 2014 | 02:58 PM
raver0789's Avatar
Surprised you said you couldn't get more out of 26psi. I'd figure with less timing and more boost there would be more power. Surprised you didn't make an easy 400, and that it died up top that fast. I know it's only a little 52mm but still. Good results though. I should visit my best buddy in Winnipeg and meet up with you two.
Old Oct 16, 2014 | 03:02 PM
I believe it would make more power on 26 lbs now on 94 octane E10, but on 91 we were getting peak timing around 10* and EGT's at 1750* :/ He ran out of time to turn it up and play some more, but we will play with that next weekend when I go up there!
Old Oct 16, 2014 | 03:03 PM
raver0789's Avatar
Soon it'll make a lot of power in that - 40 cold lmao
Old Oct 16, 2014 | 04:22 PM
Got Bewst?
Ya I would have liked to of seen 400 also. If I had more time to play around it would have happened but I had to head to work When you look at the logs on top my motor is actually out flowing the turbo. Boost drops a bit up top.
Old Oct 16, 2014 | 05:13 PM
I'm going to bring up a larger WG spring just to make sure that isn't causing the taper.
Old Oct 17, 2014 | 01:45 AM
andrewcarr1993's Avatar
Wasn't part of going turbo that you didn't need to run Meth with the previous failures...
Old Oct 17, 2014 | 08:44 AM
Got Bewst?
Partially yes haha. But AEM has come out with a fail safe kit for meth which will keep my motor from going boom if it quits this time.
Old Oct 17, 2014 | 09:28 AM
southal cobalt's Avatar
I'm confused. Is it an lsj, or an lnf? Gen 3 with direct injection. Is it true direct injection, or is it just di pistons on an lsj head? Was just wondering, because if it's true di, wouldn't you want to lean it out even more
Old Oct 17, 2014 | 09:58 AM
574's Avatar
574
Lsj. DI pistons
Old Oct 17, 2014 | 10:10 AM
Yep, just DI pistons since its a Gen 3. Still uses 80# injectors in the head.
Old Oct 17, 2014 | 10:30 AM
100% METH's Avatar
I heard my name
Let me know when it's time to do this!
Old Oct 17, 2014 | 12:46 PM
Ah I see reading > me. Lol
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
