Dyno Results Dyno pictures, videos and dyno results.
New Official Dyno Thread (2012)
Old Jul 2, 2013 | 04:33 PM
  #401
BALT06SS's Avatar
As staged07ss said its doubtful that you made 20 more whp than armcclure who happens to have a ton more work done to his car than you.
All dynos dont read the same but that would not be the problem if you had more than a little line of mods list to back up the claim to the highest whp M62 ever especially on a 2.8" pulley, that is more like a 270whp car. I can see a dyno being off by 10whp but 50!!??
I could have just said I threw on a BRFPS and made 472 but how many people would start flaming me for that. I brought pics, dyno sheets of several runs, dyno runs over lower boost and proved that I was making 10whp per lb of boost. I also found out the effeciency of the 20g started making heat at 28psi and that 27 is where its done.
You have to prove yourself around here or your gonna be known as the guy who had that dyno sheet that wasnt very accurate but it got him on the list...
Alright well I have couple other dyno sheets of me on pump gas and meth and some on e85 working my way up to 333whp that I will post when I get home. And I think my tuners wife took a vid of the pull and numbers that I will try and get
Old Jul 2, 2013 | 05:12 PM
  #402
armcclure's Avatar
Who is your tuner if you don't mind
Old Jul 3, 2013 | 07:13 AM
  #403
Staged07SS's Avatar
Administrator
Administrator
Sounds good.
You don't happen to have the same blower as I do by any chance?? H62?
Looks just like an M62 on the outside, but houses TVS style rotors with a larger outlet port. Flows more air than the M62, and could def produce the numbers you have on E85.
Did you buy the car new, and do all the work? Or did you buy it used with the current mods?
Old Jul 3, 2013 | 12:10 PM
  #404
BALT06SS's Avatar
His name is Jeremy bird. He owns power labs dyno and tuning in idaho falls, idaho
Old Jul 3, 2013 | 12:13 PM
  #405
BALT06SS's Avatar
Sounds good.
Sorry I was really busy and didnt get a chance to post those dyno sheets but I will try to today. But I bout the car used about a year and a half ago all stock. And I did all the performance to it. And that's another thing I was wondering about if maybe mine has the h62 blower on it is there any other way to tell witch blower without taking it off?
Old Jul 3, 2013 | 12:26 PM
  #406
Staged07SS's Avatar
Administrator
Administrator
My H62 has a bunch of prototype markings on it, but others had no markings.
The M62 & H62 look the same on the outside. The difference is on the inside. Higher twist rotors (120 degrees vs 60 degrees), and a larger outlet port to match the higher rotor twist.
My M62 top & my H62 bottom:
Old Jul 3, 2013 | 01:30 PM
  #407
BALT06SS's Avatar
Alright when I get some time I will take mine off and have a look. How much more potential does the h62 have
Old Jul 3, 2013 | 01:59 PM
  #408
Staged07SS's Avatar
Administrator
Administrator
Tested to produce 20 whp more at any given pulley size over the M62 by simply bolting it on (more w/ custom tuning), along with 14 degree cooler charge air temps.
Old Jul 3, 2013 | 02:29 PM
  #409
c130aviator's Avatar
WOW, learned a lot about the H62 today. NICE NICE NICE stealthy supercharger.
Old Jul 3, 2013 | 02:41 PM
  #410
ThexGovenor's Avatar
why all LSJ's didnt come with the H62 is a mystery to me...
Old Jul 3, 2013 | 02:57 PM
  #411
gm cheaped out.
Old Jul 3, 2013 | 03:03 PM
  #412
Staged07SS's Avatar
Administrator
Administrator
I hear ya man.
Old Jul 9, 2013 | 01:46 PM
  #413
Guy SS-TC's Avatar
http://s10.postimg.org/rw3edwryx/dyno_time.jpg 2009 LNF Sedan Bone Stock
Old Jul 17, 2013 | 11:32 AM
  #414
InfraRedline's Avatar
My dyno from early May at boost for boobies car show and dyno day at Modern Automotive Performance in Minneapolis. Losing boost up top somewhere, and still have to address that issue. This was right after I swapped to the 2.6, hadnt touched the tune since the 2.7, but after the dyno I only made slight changes, mostly to how the timing table ramped with the added boost moving the load farther down the timing table. The sniffer was back from the exhaust a bit so AFR wasnt as lean as it seems, although it was slightly leaner than I would have liked, and I wish I would have had time to adjust it before the dyno, but it was snowing the day before Ill get all the kinks worked out and hopefully dyno again at the next event in October.
Mods are TVS/2.6/I/H/DP/E/98#/PH/C/RS/DU/T/E85
Heres the graph. Its 370whp/292tq
Old Jul 17, 2013 | 12:39 PM
  #415
Staged07SS's Avatar
Administrator
Administrator
I will try and get the dyno thread updated later this afternoon
Old Jul 17, 2013 | 04:23 PM
  #416
[IMG]http://i235.photobucket.com/albums/ee138/Taylor_Redlines/image_zpsf1a35d69.jpg[IMG]
My afr's at the sniffer were 13 as well at 27 psi but were more like 12.5 on E85, with your fuel mods and just a turbo swap that thing would be insane if the block stays together. Cant wait to see your turbo swap.
Old Jul 19, 2013 | 11:22 AM
  #417
Staged07SS's Avatar
Administrator
Administrator
Update: 7-19-13
InfraRedline
Guy SS-TC
Added!
Old Jul 19, 2013 | 11:29 AM
  #418
I am pretty excited. Going to try to ride that fine line of safety and fun...see how it pans out
Update: 7-19-13
InfraRedline
Guy SS-TC
Added!
Thank ya sir!
Old Jul 19, 2013 | 05:33 PM
  #419
Thank ya sir!
it pans out well on E, the stuff even leaned out in the tune is unknockable. Is that a word? Unknockable? LOL, it is now.
Old Jul 19, 2013 | 05:38 PM
  #420
Oh I'm not worried so much about detonation, just whats gonna give up first on my car Maybe nothing? Stock block lotto lol
Old Jul 19, 2013 | 06:39 PM
  #421
574's Avatar
574
I beg to differ
Old Jul 20, 2013 | 06:09 AM
  #422
Killa SS's Avatar
I guess I could post my dyno in here and steal that #5 spot for top 5 High HP turbo lsj
Old Jul 22, 2013 | 07:12 AM
  #423
Staged07SS's Avatar
Administrator
Administrator
Do it!
Old Jul 22, 2013 | 08:01 AM
  #424
Killa SS's Avatar
Do it!
Can I post pics from the css.net app?
Old Jul 22, 2013 | 09:31 AM
  #425
armcclure's Avatar
Upload to photobucket mobile then just copy the IMG code
