Dyno Results Dyno pictures, videos and dyno results.
The Official Dyno Thread 2015
Old Apr 18, 2016 | 03:34 PM
  #426
Originally Posted by 100% METH
Thank you very much everyone
@ECaulk - Only the 2.8 pulley
Once we broke 400whp, I didn't see a need.
I'm kicking myself still for not spraying the 50 wet shot.
I think other than making near 400whp on a 2.8 pulley with a stock intake and throttle body.
The intercooler system is nearly entirely stock.
Stock manifold, stock endplate... Only have the large custom made TJolley Griffin Front Mount
Near 400 on a stock intake? Damn, so there is proof it's not a limiting factor until you're way up in the power department, although its hard to say if it was the throttle body or the intake that was the limit (i'm going to lean towards mostly the throttle body, but I don't know the diameter differences or the surface area of the filter)
Old Apr 18, 2016 | 03:41 PM
  #427
100% METH's Avatar
400whp is obtainable on this engine with the 2.8, using the stock air box mod intake and TB.
I could of leaned out into the 12.5-12.7 AFR department to make the additional 6whp
Other option would of been to pulley down to a 2.7/2.6/2.5 or even 2.4
Best option... run a better fuel; E98, Methanol, FTW.. ETC
Old Apr 18, 2016 | 03:42 PM
  #428
100% METH's Avatar
stock intake and tb gained 30hp over the bigger stuff? damn
other way around
Old Apr 19, 2016 | 07:19 AM
  #429
Staged07SS's Avatar
Administrator
Administrator
Been saying this for years, but everyone wanted shiny noise makers on their SS/SC instead of putting the money they could saved towards real power mods.
I tested the stocker against injen and aem, and the stocker outflowed both of them by nearly 3 lbs/min.
Old Apr 19, 2016 | 07:40 AM
  #430
I believed you from an airflow standpoint, now we have dyno results to backup the airflow data.
I should do this for the LNF, but finding funds for a day dyno rental is tough when I'm getting married in 2 months
Old Apr 19, 2016 | 07:53 AM
  #431
Staged07SS's Avatar
Administrator
Administrator
Congrats on getting married soon as well!!
Old Apr 19, 2016 | 12:52 PM
  #432
Staged07SS's Avatar
Administrator
Administrator
KMO43, Shanman, 100%METH added!!
Steven, can you write your mods down for me as per the legend. I'll get those added as soon as u do.
Thanks!
Old Apr 19, 2016 | 03:24 PM
  #433
100% METH's Avatar
Originally Posted by staged07ss
kmo43, shanman, 100%meth added!!
Thanks!
tvs1320|2.8|i|tb|h|cd|e|t|he|vs|ph|C(ZZP STG 3)|e85|fs|fprw|rs|1200cc fic inj|bs
not sure how you wanna add 11:1 compression
Old Apr 20, 2016 | 01:02 AM
  #434
Shanman's Avatar
Bro very nice!!! Super Excited to see stg 3 cam numbers. Impressive powerband curve up top, that thing is frickin screamin! Are you running ferrea VS for those Revs?
Old Apr 20, 2016 | 01:59 AM
  #435
100% METH's Avatar
supertech #75
LSJ oem lash adjusters
I'm loving the 5000 rpm of useable torque
It's finally become a reality
Old Apr 20, 2016 | 02:05 AM
  #436
100% METH's Avatar
Originally Posted by 06blackg85ss
very nice
Thanks
When you going to get that TVS setup going again?
Old Apr 20, 2016 | 06:32 AM
  #437
06blackg85ss's Avatar
waiting on advise to pick up a new block. hopefully in about a month or so we'll have it back out.
apparently arp 625+ at 105ftlb was too much for the block to take.... only cracked on one hole, but that was enough to take out the block.
should have my car back out on the dyno in a few weeks, just waiting on ottp to send phil his damn turbo setup so we can get that thing back together
Old Apr 20, 2016 | 07:16 AM
  #438
Staged07SS's Avatar
Administrator
Administrator
New addition to the legend block....
CR 0:0 = Compression Ratio
Ex. CR 11:1
Old Apr 20, 2016 | 01:48 PM
  #439
100% METH's Avatar
He back off the stud before torquing it so it didn't bottom out?
Old Apr 20, 2016 | 01:57 PM
  #440
yup
Old Apr 20, 2016 | 04:24 PM
  #441
Shanman's Avatar
supertech #75
Holy hell supertechs. Didnt know they were capable of 9k. So you made peak power around 8500. ZZP's website stated you make power to 9500. How's the idle? Is it a pain to drive on the street?
Old Apr 20, 2016 | 04:29 PM
  #442
100% METH's Avatar
ZZPs claims a lot of things
Look at the second graph, Trevor hit the button to shut the dyno off a bit early but it looks like it's still semi-climbing past 8800.
Idles normal; have it set to 950 at the moment, and you can hardly hear the cams.
It doesn't drive like stock; but it's not difficult to drive at all.
Old Apr 21, 2016 | 07:20 AM
  #443
Staged07SS's Avatar
Administrator
Administrator
That they do, and a lot of it is false!! Lol
Old Apr 23, 2016 | 08:43 AM
  #444
advise's Avatar
all there cam sets are rated incorrectly i barely made power to 8k with my old s2 cams
plus they use a lift measurement different then the industry standard
Old Apr 27, 2016 | 03:39 PM
  #445
100% METH's Avatar
That's why I didn't bother going with the stage 2 cams
STG 3 drivability is nearly the same, and they allow higher revving
Old Apr 28, 2016 | 07:22 AM
  #446
Staged07SS's Avatar
Administrator
Administrator
I make peak power at 7650 rpm with the S1 cams, which is a good deal more than their claimed 500 rpm increase over stock.
So they are all over the place with their ratings.
Power adders and head flow will make some of this vary a bit as well.
Old Apr 28, 2016 | 01:24 PM
  #447
yup pretty much. We'll see where the stg2 sc cams start falling off on my turbo setup whenever I can make a clean pull.
Old May 8, 2016 | 10:33 PM
  #448
nhanson's Avatar
Originally Posted by nhanson
391whp/338wtq
LE5/80s/PTE5431-16psi/E85/PH/82lb VS/Stock LSJ water cooling with dual pass/
Herro?
Old May 9, 2016 | 12:15 PM
  #449
100% METH's Avatar
Where's the stock LSJ line?
Old May 9, 2016 | 12:21 PM
  #450
Staged07SS's Avatar
Administrator
Administrator
There are only two stock graphs. No extra line.
