Dyno Results Dyno pictures, videos and dyno results.
This should put me into the top 10 :)
Old Mar 27, 2009 | 11:29 AM
Rodimus_Prime's Avatar
Hit up the dyno again yesterday 298hp, 254tq, same mods as my previous 12th best for the LSJ motor
Only change in hardware was an LS4 throttle body, not sure if theres a coding for that
anyways heres the sheet
the dyno is a dynapack dyno, same as last time also
Old Mar 27, 2009 | 03:54 PM
-Jayson-'s Avatar
seems low for a TVS, what size pulley are you running? Supporting Mods?
Old Mar 27, 2009 | 03:55 PM
BumbleBee's Avatar
pretty cool
Old Mar 27, 2009 | 04:18 PM
ralliartist's Avatar
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/298-8whp-f-my-life-162888/
Old Mar 27, 2009 | 04:36 PM
Area47's Avatar
Rent me! per hour
rev it higher.
Terminator2's Avatar
That graph is kinda weird at the top end it look like it looses a little power then starts pulling upward again. Maybe that is where he let off at the end of the run. How come you aren't pulling to almost 8K like Area47? These supercharged cars make way less peak torque than us turbo guys but the torque does not drop off much at the higher rpms so it enables very good peak HP.
Old Mar 27, 2009 | 04:58 PM
Area47's Avatar
Rent me! per hour
he doesn't have the valve springs, or the nuts to do it
lol!
::runs::
Old Mar 27, 2009 | 05:00 PM
Black SS/SC 06's Avatar
lol!
::runs::
LMAO! Show him the light
Old Mar 27, 2009 | 05:01 PM
umrdyldo's Avatar
Get some valve springs and push it over 300 WHP easily. Bet that super screams at 8k RPMs
Old Mar 27, 2009 | 06:31 PM
lol!
::runs::
. Still on stock valvesprings that explains it then. Bet it makes peak power at about 7400 rpms or so.
Old Mar 27, 2009 | 07:38 PM
I have a completely stock motor, no internals, no cams, therefore the rev limiter is at 7200. The main issue was spark blowout this was killing the torque once the boost got above 19 or so, so once thats ok, better numbers should occur. I have no idea how or where to get valvesprings done so I can't do that.
Old Mar 27, 2009 | 11:41 PM
Darkmanx's Avatar
what pulley are you on stock or 75mm? and how the hell all you guys keep getting spark blowout
Old Mar 27, 2009 | 11:53 PM
80mm pulley, and I'm running stock heat range plugs gapped at .040, thats why theres blowout at 21.5psi
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Stuff
Oct 1, 2015 05:47 PM
Tupp
Sep 30, 2015 08:18 PM
