alternator hookup
lol well logically if its bigger then 16g its either power or ground. i just assumed that gm would be cheap and only use brass posts for the pos not the neg. but i honestly dont know i just made that guess. a multimeter will tell you thou
sweet thanks for posting your results. helps anyone else who might be in ur shoes later on.
but just for clarification the fuseable link is on the alt or the brass post had short wire to a fuseable link then to the fusebox?
actually no. i thought it would be hooked up that way to but how its hooked up on the 05 2.2 is connected to the brass stud on the alternator then to the starter solenoid where the 4 gauge wire leading to the under hood fusebox. Solid piece of 14 gauge fuseable link making the connection. what they are relying on is when there is to many amps drawing the whole wire melts instead of a fuse popping.
WhineSSbaby
Sep 1, 2020 12:39 PM
