Aux port
Old Oct 8, 2012 | 04:37 PM
Play Pat's Avatar
Aux port
So when I had my my aux cord in my radio, I hit it by accident and now it only plays music on the back speakers. Any way of fixing this?
Old Oct 8, 2012 | 04:40 PM
GRok25's Avatar
try using a different AUX cord, ive broken like a dozen of them haha
Old Oct 8, 2012 | 04:43 PM
Gelladuga69's Avatar
Just a guess, but maybe you somehow changed the radio settings to only play/fade to the back speakers.. I don't have the stock radio for awhile, but I think you just hit tune knob and it'll allow you to change the speaker settings.
Old Oct 8, 2012 | 04:47 PM
cluelessk's Avatar
Probably bent/broken end on aux cord. Had a drunk friend break mine 2 weeks ago.
Old Oct 8, 2012 | 11:07 PM
Play Pat's Avatar
Tried all that, I think its the metal sides in the radio that touches the cord to play sound. I wonder how I can fix it without taking the radio apart. I would get a different dash but that wiring harness is too much money.
Old Oct 9, 2012 | 12:51 AM
cluelessk's Avatar
You could just replace the stereo itself.
Why would you need the dash?
Old Oct 9, 2012 | 03:12 AM
EmperorJJ1's Avatar
i think he means a new aftermarket radio.
regardless the only cheap method would be opening up the old radio. and thats assuming u dont break it. a new stock radio will also cost the programming from the dealer + however much the unit is
aftermarket will cost unit, install and installation pieces
You might be able to swap faces on a stock unit to avoid having to do the reprogram. but im not sure how possible that is
Old Oct 9, 2012 | 04:44 PM
Play Pat's Avatar
My plan was to just change out the stock to another stock one but programming will cost me. Just seeing anyone knew a secret to fixing this without taking everything part. Guess I gotta take it apart and hope for the best.
Old Oct 10, 2012 | 12:58 AM
EmperorJJ1's Avatar
on the 05-06 radios the "face" comes off and if thats the case u can swap that without worrying about the programming charge. BUT idk if thats the case with the newer radios
Old Oct 10, 2012 | 02:12 AM
sLAsh's Avatar
Face comes off 07 & 08's. Jack is on it's own seperate circuit board so you might be able to just solder in a new jack.
Old Oct 11, 2012 | 01:55 AM
EmperorJJ1's Avatar
if thats the case, id check to see if its the jack or the solder joint that failed first. good chance the jack is intact but the solder joint is busted
Old Oct 11, 2012 | 04:22 AM
sLAsh's Avatar
If you need to remove the circuit boards from the faceplates, the knobs stay attached to the boards so it is easiest to push the knobs in rather than pulling on board.
agentirons
Oct 16, 2015 02:11 AM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
