dynamat on a Cobalt 05 LS door
Old Nov 11, 2006 | 06:19 AM
reddecember's Avatar
I pulled off the plastic moldings on the door and behold! there is a clear sheet of plastic glued onto the metal separating the wires and things that are between the molding and the metal. Should I dynamat strait onto this plastic? Or would it be better to remove this plastic sheet so I can dynamat strait to the metal?
Advice?
Old Nov 11, 2006 | 07:40 AM
xspyder85x's Avatar
take th plastic off first, its better to do this while its colder, the glue will cut off nicely. take a razor and cut the black while you pull it apart.
Old Nov 11, 2006 | 10:03 AM
sunrise_mj's Avatar
dont cut it all off... leave some around where the door lock arm passes and the door handle bar thing passes... that way its not sticky right there...
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
satisfied
Oct 19, 2015 12:35 AM
jthwjde
Sep 7, 2015 09:24 AM
