Ebrake Bypass
Old Nov 12, 2012 | 01:18 AM
2007blkSS's Avatar
Ebrake Bypass
Does anyone know where you're supposed to wire the wire for the ebrake video.. I know their is a way to bypass it so it plays all the time
Old Nov 12, 2012 | 01:49 AM
brian.olsson's Avatar
what kinda deck you have, some are different, but most are just grounded, some you have to hook to a switch and than to a ground so you can toggle it on and off so it thinks you have the ebrake on
Old Nov 12, 2012 | 02:12 AM
Squints's Avatar
you can also tie it in with the stereos ground wire in the wire harness thats how i did mine in my 03 dodge
Old Nov 12, 2012 | 12:16 PM
2007blkSS's Avatar
A JVC KW-AV70BT
This what it looks like from the back
Old Nov 12, 2012 | 02:30 PM
n8g's Avatar
n8g
Same question but for an Alpine IVE-W530. It has a foot brake and hand brake wire. I tried tying them together to the ground but it did not work. The manual says you have to put the foot brake on 1st, then the hand brake. Do I need a double switch of some sort?
Old Nov 12, 2012 | 02:46 PM
cluelessk's Avatar
You just hook it up to switched power for a JVC deck. Pioneer decks need either a switch or relay installed to use the video function.
Old Nov 12, 2012 | 03:02 PM
EmperorJJ1's Avatar
lol for the alpine idk why it would want a foot brake to begin with thats stupid.
Old Nov 12, 2012 | 04:01 PM
Gelladuga69's Avatar
Check eBay for an automatic switch for your head unit.
I got one for mine from there and it works flawlessly. Wired up 3 wires.
Old Nov 12, 2012 | 05:13 PM
cluelessk's Avatar
Foot brake = floor ebrake.
Old Nov 13, 2012 | 01:34 AM
EmperorJJ1's Avatar
mmm no dont think so....
To watch a video source, your vehicle must be parked with the ignition
key in the ACC or ON position. To do this, follow the procedures below.
1 Push the foot brake to bring your vehicle to a complete
stop at a safe location. Engage the parking brake.
2 Keep pushing the foot brake and release the parking
brake once then engage it again.
3 While the parking brake is being engaged the second
time, release the foot brake.
http://support.alpine-usa.com/produc...VE-W530_EN.pdf
Old Nov 13, 2012 | 01:38 AM
EmperorJJ1's Avatar
even thou its a bunch of bullshit it sounds like the foot brake is the normal brake
Old Nov 13, 2012 | 02:07 AM
rectorc08's Avatar
I just hooked up a Pioneer and it wouldnt work when it was grounded because its a 2012 model so I went and got a Automotive relay and it worked perfectly. Its a double ground relay because it needed to signals sent before it would work. Found the tutorial online. Maybe look into the relay. It was like $6 or so at RadioShack and has worked for 4+ months no problem.
Old Nov 14, 2012 | 09:28 AM
n8g's Avatar
n8g
I will have some time this weekend to mess around with it. Not only can I not watch any video, but I can't access any of the settings menus. I will try some sort of double rocker switch or possibly 2 different switches.
Old Nov 14, 2012 | 10:22 PM
EmperorJJ1's Avatar
right u need the reg brake connected for it to work. its pretty bullshit
Old Nov 14, 2012 | 11:51 PM
2007blkSS's Avatar
I just grounded it and the video worked while i was driving..
Old Nov 15, 2012 | 02:29 AM
EmperorJJ1's Avatar
ya jvcs are one of the most simple to do. that alpine of n8g's... not so much
Old Nov 20, 2012 | 03:03 AM
VancouverTurbo's Avatar
Pac Audio TR-7 For alpine bypass. comes pre programmed with a wiring diagrams to do it. Some need to see ground after accessory is turned on like pioneer, alpine needs this:
1. depress the brake pedal
2. engage the parking brake
3. release the parking brake
4. engage the parking brake
5. release the brake pedal.
Automated process with no switchs to mount versus saving money
Old Nov 24, 2012 | 12:35 PM
n8g's Avatar
n8g
^^ Thanks for the tip. I didn't get a chance to mess with it yet.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
Hugger1975
Oct 15, 2015 03:28 PM
allpro666
Sep 23, 2015 07:47 PM
DevZX
Sep 16, 2015 06:19 PM
