EPS 2 Amp Interior Fuse - Wire Locations
Old Apr 4, 2019 | 12:34 PM
Boyes50's Avatar
Hi Everyone,
In the middle of stripping the interior harness out of a 2006 Cobalt SS, the car is destined to be an Asphalt Oval Racecar. In the midst of cutting wires, I have accidentally cut one of the EPS wires, and have therefore lost EPS. I have removed all loom and tape and traced all wires, and found the wire. However, I have no clue where it is supposed to go! On the EPS Module, the smallest connector come out and branches into several wires, I believe 5 or 6. All these wires are good, and one Red Wire goes directly from the module to the BCM Interior Fuse Panel. This feeds into the back of a 2AMP Fuse location for the EPS. Coming out of that is a Red Wire again, and this wire has been cut. I can upload some pictures if needed. This wire is LIVE, and therefore must be feeding power to something for the EPS to function. Is there a full schematic which shows exactly how the EPS wiring works and where each wire goes?
Thanks!
Matt
Old Apr 4, 2019 | 01:55 PM
Kolt's Avatar
BCM connector 4 (C4).pdf
EPS Connector end views (C1, C2, C3).pdf
EPS Schematics.pdf
TacoCodeRed
Apr 11, 2018 02:48 PM
06cobaltncng
Aug 7, 2013 07:36 PM
2007blkSS
Nov 24, 2012 12:35 PM
WhiteFiver
Aug 25, 2009 01:44 AM
07 SS/SC
Feb 13, 2008 10:58 PM
