factory stereo+two 12's
Old May 3, 2011 | 01:35 AM
FatSam2010's Avatar
I have an 06 Cobalt lt sedan and i have the stock pioneer system with the 10" woofer in the trunk, i want more bass but want to keep the stock head unit to make it look cleaner in side so i got my old amp and subs, i purchased a Line Output Converter from bestbuy and tried to splice the wires from the stock sub so that the 10" and the 12's hit together at the same time instead of left bass and right bass, i cant seem to get them to work, possibly because im not sure which wires are which going into the factory sub...
if someone could tell me which wires are what that would be a great starting place...
as of now the subs hit depending on which side is hitting, and that sucks because the 12's are hitting on the right side which way over powers the left side and makes it sound like ****...
also if anyone know what is rattling inside the car that would be nice because that also sounds like ****, it sounds like it's coming from the back window, thanks
Old May 3, 2011 | 03:33 AM
EmperorJJ1's Avatar
the rear deck and the clips on it are whats rattling. on the aftermarket amp when you disconnect one rca so theres only one still connected what happens to the bass? try the opposite single one and what happens then as well?
Old May 3, 2011 | 07:21 AM
FatSam2010's Avatar
ive tried doing that like mono or whatever it is, it still plays only say the right side bass, im almost sure its because i have the wires spliced wrong, but i dont know which wires are which so i cant be sure
Old May 3, 2011 | 03:47 PM
cobalt2010's Avatar
i thing its best to go ahead and tap into the rear speakers for the amp power, thats what i did. until i put in aftermarket stereo
Old May 3, 2011 | 04:08 PM
FatSam2010's Avatar
i didnt do that because the wires for the rear speakers were so far apart and the adapter thing didnt have much slack for them, but i think my friend ended up getting it to work, hits hard for some shitty subs
Old May 8, 2011 | 05:05 AM
EmperorJJ1's Avatar
what subs do u have?
Old May 9, 2011 | 11:00 PM
FatSam2010's Avatar
they're pretty shitty man, they're like direct xtreme 12's or something like that with a 1200W sony amp but im not complaining cause i found them in an abandoned dorm and kept them
Old May 9, 2011 | 11:54 PM
z062007vette's Avatar
Here is my how-to on this, but I don't have the pioneer system.
https://www.cobaltss.net/forums/how-...-wires-246466/
Hope that helps you.
Old May 11, 2011 | 12:07 AM
FatSam2010's Avatar
i got it all set up man, but thanks, a friend of mine just bridged the subs and they sound really good now
Old May 11, 2011 | 12:10 AM
EmperorJJ1's Avatar
watch out if they truely are shitty subs then they probably shouldnt be bridged. not for the subs sake but the amps
Old May 11, 2011 | 12:31 AM
FatSam2010's Avatar
i dont run them hard, i have the amp turned almost all the way down and the bass level in my car like the second notch from the lowest, but yea ill keep an eye on it, thanks for the heads up man
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
importkiller
Sep 30, 2015 07:18 PM
nathan112i
Sep 30, 2015 07:12 PM
cw383
Sep 30, 2015 12:41 AM
