Flickering electrical system. Help!!
Old Feb 28, 2013 | 08:37 AM
toned-e94's Avatar
I bought my 2005 cobalt with 109xxx i am currently at 120xxx. Ever since I had the car my entire electrical system flickers. Dash lights, headlights, brake lights, everything. The alternator and battery were checked and they are fine. Alternator powers everything back up properly and battery is strong. We checked a few grounds and cleaned power wires but still flickers. As the RPM's go higher everything flickers faster. If you have any suggestions I can try to check or information please let me know! Thanks
Old Feb 28, 2013 | 09:49 AM
TommyP's Avatar
AWD > FWD
make sure the positive battery post on the fuse box is tightened down.
Old Feb 28, 2013 | 10:22 AM
toned-e94's Avatar
Yeah we took that completely off, cleaned it, and still nothing.
Old Mar 1, 2013 | 02:49 AM
EmperorJJ1's Avatar
if increased RPMs makes it change that makes me lean towards a gound issue vs power issue. I was going to say check the 50a fuse and holder in the back for the BCM but id look into the front grounds and batt ground. hows the neg bat terminal as well? they are built pretty shitty and can be loose
Old Mar 2, 2013 | 11:20 AM
toned-e94's Avatar
The battery ground is pretty tight, where is the fuse talking about? Interior fuse box or engine bay, and what is the BCM?
Old Mar 2, 2013 | 11:29 AM
EmperorJJ1's Avatar
there should be a fuse right by the battery
Old Mar 5, 2013 | 10:18 AM
toned-e94's Avatar
Ok I'll check that. If the fuse is popped you think that could cause flickering?
Old Mar 5, 2013 | 11:48 AM
EmperorJJ1's Avatar
no but if its loose or something it might. again im leaning towards something not grounded right
Old Apr 10, 2013 | 12:25 PM
toned-e94's Avatar
still couldnt find anything. im not to sure where to go with this on my own. I might consider bringing it to chevy just so the problem is solved. its very frustrating
Old Apr 10, 2013 | 12:30 PM
Pepsi's Avatar
A buddy of mine has a contour SVT and same problem. Can't figure out whats wrong
Old Apr 10, 2013 | 12:57 PM
redcobalt07's Avatar
Do you have any aftermarket electrics?
Old Apr 10, 2013 | 02:17 PM
buildmeanempire's Avatar
Don't take it to a dealer. They will more than likely just say they can't find the issue and then you will be out $100 or more.
Old Apr 18, 2013 | 12:26 PM
toned-e94's Avatar
I do have a sound system but the problem occured before anything was done to it.
Solaris99
28
Mar 15, 2017 01:22 PM
ernnyyes
Oct 2, 2015 05:16 PM
Cptnslo
Sep 24, 2015 09:32 AM
717ssbalt
Sep 2, 2015 10:49 PM
