gm xm antenna
Old Apr 23, 2011 | 11:21 AM
ericgt79's Avatar
gm xm antenna
is it possible for me to reuse the OEM xm antenna and if so how do i find the wires so that i can connect my xm to my clarion nx500
Old Apr 23, 2011 | 11:38 AM
ericgt79's Avatar
to the top
Old Apr 23, 2011 | 06:50 PM
Q Bert's Avatar
I have never had allot of luck trying to use the factory antennas with after market radios. I'm sure it's possible but probably not practical.
edit: just read the faq and looks like others don't recommended it either.
Old Apr 23, 2011 | 06:55 PM
chris88z24's Avatar
The factory antenna is the same thing as what comes in most XM kits for aftermarket radios, provided you have the XM square and not the "shark fin". The Pioneer XM adapter for sat-ready HUs is the same exact thing as what came on the top of my 07 from the factory...
Old Apr 24, 2011 | 04:26 AM
EmperorJJ1's Avatar
someone put a how to on here about cutting it to make it fit and it worked for them idk where thou ill have to look again
Old Apr 24, 2011 | 02:30 PM
ericgt79's Avatar
i dont even know where to find it
the people that put my **** in are fucken worthless and i decided to **** my own car up from now on instead of paying those ******** to do it.
can i also run my gps antenna inside my car and it will still work anyone know? that **** is scratchin the roof of my car and its pissen me off
Old Apr 24, 2011 | 08:11 PM
EmperorJJ1's Avatar
you can it works best outside of the vehicle thou. You can also throw some 3m double sided tape on it to keep it in place
Old Apr 24, 2011 | 08:12 PM
EmperorJJ1's Avatar
https://www.cobaltss.net/forums/how-...-antenna-7245/
whoops this sint the one i was lookign for
Old Apr 24, 2011 | 08:33 PM
BlackSS185's Avatar
Yea it works I did it to mine there's three wires in the factory antenna ( if you have onstar etc on my 09 colors are brown black and purple I believe) there is a certain frequency/resistance that the xm antennas need to be to work so only one of the three will work good. Once u drop the bak of the head linner you will see them. I used the brown coaxle cable in the factory antenna cut my aftermarket antenna off and installed a female coax end same as the end that plugs into Ur aftermarket xm box (mini coax) you have to make sure the center is connected good and the outter ground is connected. Make sure the dont touch each other. I wish i had pics i was gonna make a how to but I figured it would have gotten flamed up lol but it took a little trial and error. But it can be done. Also I same can be done for gps if you know what Ur doing lol
Old May 6, 2011 | 02:42 AM
EmperorJJ1's Avatar
heres the thread you need
https://www.cobaltss.net/forums/elec...0/#post5757885
chefhhr
Oct 26, 2015 10:36 PM
dieGone
Sep 23, 2015 10:20 AM
truray4
How to Guide
Feb 27, 2008 09:51 PM
Iroc
How to Guide
Feb 9, 2006 11:54 PM
