head unit question
Old Oct 9, 2006 | 03:21 PM
cruisn's Avatar
head unit question
where is everyone getting a switchable 12v source when installing an aftermarket deck, I have the 25$ wiring harness and it came with a extra piece of wire for power. I want to know where I can tap in for a source. anywhere under the dash would be nice. thanks for the help.
Matt
Old Oct 9, 2006 | 03:39 PM
LSJ PUP's Avatar
That 12v switched wired should have a fuse clip on the end. Either way, you best bet is to tap in onto either your sunroof (if you want to keep your radio on when u turn your car off...until you open the door) or your wipers fuse. The sunroof is a 15amp while the wipers run off a 10amp. Make sure you connect it to the size that doesn't have a voltage reading. If you do, you wont have the ability to have that fuse protect your head unit.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
agentirons
Oct 16, 2015 02:11 AM
Sep 28, 2015 12:51 PM
