Help Me Out Guys!!!!!
Ok I've Been Having Powersteering Problems Sence I've Own The Car, And I Took It To The Dealer ....9 Times Already, But This Last Time The Replaced My Bcm Again....but Now My Stereo Does Not Work....well It Turns On, But No Sound...i've Checked The Fuses There Find Any Other Ideas.....ohh Btw I Have The 7 Speaker ****
stock amp is probably gone or not tuning on
test the pink wire on the harness for voltage (12v) with the stereo on and you'll get you answer if the amp is broken or its the remote wire. You might as well check the ACV on the speaker wires at the stereo to see if its putting out signal (seeing as you could have a broken stereo as well but most likely its the amp)
Last edited by EmperorJJ1; Nov 27, 2008 at 11:57 PM. Reason: Automerged Doublepost
roth
Sep 26, 2015 12:16 PM
