Help with single din 2007 base install
Old Apr 9, 2012 | 01:45 PM
breds2k's Avatar
Hey guys my car is a LS 2007 base model so no onstar or pioneer, i just picked up the single din kit with wiring adapter and antennae adapter, also got the PAC interface.
Now I want to start by saying this is just for gathering information, i havent even look at the wiring yet or tried to hook anything up but i hate getting deep into a projector then finding out i have to go to home depot and i need to get a ride.
I have installed stereos before with just simple color to color butt connections. but i never used an interface like this, and the Double Din walkthrough seems like it more than what i have to do here, plus it seems like 05-06 is different than 07 and 08+ is different as well.
So im wondering what has to be done to install my headunit (older Jensen UV8 dvd) will the connections clip together and then all i have to do is connect the speaker wire? Will i need to run a power wire for my 07? A guy told me at a recent meet that the power goes through the PAC so i dont need to, but i see all these other people that have to run a power wire.
Im just confused and not comfortable enough to go poking around yet. Any help is appreciated.
Old Apr 9, 2012 | 08:34 PM
breds2k's Avatar
Bump, just looking for a little help here please.
I search single din install, stereo install, single din, radio install. Only found the walkthrough for a double din.
Old Apr 9, 2012 | 08:39 PM
breds2k's Avatar
just found this thread, saying its pretty straight forward just match up the wires, but it doesnt say anything about the power wire, do I need to run seperate power?
Old Apr 9, 2012 | 08:43 PM
conerboner's Avatar
you don't need a seperate power wire unless you're hooking up an amp iirc. or maybe that was just because i was using a line out converter before i got my double din pioneer
Old Apr 9, 2012 | 08:44 PM
breds2k's Avatar
ok i just found a couple older threads that have given me some info, i just had to change the search words around a bit, im just hoping that i have the right harness and everything now.
Old Apr 9, 2012 | 09:44 PM
breds2k's Avatar
also ran into an issue, im missing the "cage" metal piece that goes around the single din, i didnt use it on my last car because it had a special kit dash kit rather than universal, where the hell can i buy another one of these?
Old Apr 10, 2012 | 02:42 AM
EmperorJJ1's Avatar
just read the instructions that came with the interface...
regarding the cage see if any local audio shops have them u might have to get a diff one and make it work.
Solaris99
28
Mar 15, 2017 01:22 PM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 28, 2015 12:51 PM
