keeping stock head unit?
Old May 8, 2008 | 09:35 AM
Razmus's Avatar
sorry if this has already been covered, i just joined and am not good with the search feature yet...i am planning on replacing all 7 of my stock speakers, and adding 2 aftermarket amps, but i want to keep my stock head unit. has anyone done this yet, and if so, what kind of problems should i expect?
Old May 8, 2008 | 09:43 AM
Pontiac.G5's Avatar
https://www.cobaltss.net/forums/show...stock+headunit
should help
Old May 8, 2008 | 09:47 AM
Razmus's Avatar
thanks...did you replace all of your speakers too, or just add subs?
Old May 8, 2008 | 09:50 AM
Pontiac.G5's Avatar
i just added subs... which are out now but thats how i did it... if you talk to emperorJJ1 he can help you out alot...
Old May 8, 2008 | 09:57 AM
Razmus's Avatar
will i be able to turn my sub off, or down all the way, if i keep the stock head unit?
Old May 8, 2008 | 10:00 AM
Pontiac.G5's Avatar
https://www.cobaltss.net/forums/electronics-audio-video-49/updated-general-stereo-faq-read-96094/
number 16 should help too...
you will be able to turn it off... jus put a switch in the remote wire
Old May 8, 2008 | 10:49 AM
Razmus's Avatar
emperorjj1...after looking through some of your posts, it appears you are the man to ask about this. i want to replace all 7 of the stock speakers, but keep the stock head unit. i have ordered 2 sets of speakers: pioneer ts-a1702c 6.5 woofer and tweeter components with crossovers...50 watts rms max, and pioneer ts-a6992r 5 way 6x9s...80 watts rms max. i will use a pioneer gm-4300f amp...40x4 rms, to power these. 1 10" pioneer ts shallow subwoofer...250 watts rms max, i will use a pioneer gm-d8400m amp...300x1 rms max, to power this. i also ordered a jl audio cleansweep factory sound processor, which will supposedly clean up the factory head units output, so that my new amps have a perfectly clean signal to use. i would like to know if the speakers, including the sub, will bolt right into the factory locations without much trouble. i would also like to be able to turn down, or completely turn off the sub from inside the vehicle...probably using a volume control ran from the amp powering the sub...also where would you mount that volume control? do you think the amp i have ordered to power the sub will be too much, because pioneer also makes the gm-d7400m amp...200x1 rms max. and i would like your overall opinion...what types of problems will i run into trying to do this, and do you think it will sound alot better than stock as far as sound quality and bass?
Old May 8, 2008 | 11:07 AM
Pontiac.G5's Avatar
i do see a problem with this....
Old May 8, 2008 | 11:26 AM
Razmus's Avatar
i was thinking just turn the gain down a little on the 300 watt amp, instead of using the 200 watt amp at full power?
Old May 8, 2008 | 11:43 AM
Pontiac.G5's Avatar
you would still have a possiblity of blowing your sub... but if emperorjj1 gets on here he could clarify a bit better for you...
Old May 8, 2008 | 01:04 PM
EmperorJJ1's Avatar
I'm not 100% familiar with the clean sweep but this sounds like a heck of an install. Any idea who is doing it?
Speakers will bolt in no problem and i would recommend attaching the amps to the back of the rear seats. You are going to want to do an amp bypass at some point... which i explained for another memeber and is stickied on this section. Im going to assume the cleansweep is much like the 3sixty.2 unit that i have myself (360 was made after the clean sweep to be a competitive product) and has high level inputs. I would attempt to install it in the dash behind the HU and run RCAs to the amps from there. Also it has the option to add a remote so that might an option as far as sub control and like G5 stated you can always add the switch on the remote wire to manually turn off the amp/sub as long as you run seperate wires for the mids and sub amp
Old May 30, 2008 | 08:29 PM
madlion's Avatar
how about the shallow mount diamond audio hex? or does it have to be pioneer?
Old May 31, 2008 | 01:19 AM
EmperorJJ1's Avatar
as long as it fits... if i remember correctly rage915 tried the shallow 10 and it was too "wide" for the stock box. he went with a kenwood shallow, looks clean
Old May 31, 2008 | 12:53 PM
madlion's Avatar
kenwood?!? im a pretend audiophile! wonder if the dremel will take car of the wideness factor?
Old Jun 1, 2008 | 03:00 PM
EmperorJJ1's Avatar
pioneer def isnt audiophile quality... sry to bust ur bubble but its not even a normal linear woofer
Old Jun 2, 2008 | 07:11 AM
Mastodon's Avatar
whats up with all these people wanting a stock head? anyway us rockford amps they are my personal favorite.
Old Jun 3, 2008 | 06:24 PM
-the.k.w.c-'s Avatar
if u wanna keep the stock head unit get a jl audipo clean sweep ... or alpine imprent or mtx re Q
ineedacobaltss
Nov 7, 2015 02:25 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 28, 2015 12:51 PM
Sep 27, 2015 08:53 PM
