Need your help guys!
Old Jan 12, 2007 | 01:23 PM
streetracinazian's Avatar
Talking Need your help guys!
hey everyone, i have a few questions that i need help with:
i have an alpine cda-9811 headunit that's going in for the factory, but from what i have read, the stock headunit puts out 228watts total to six speakers, and my alpine headunit only puts out 50x4.
do you think this will make a big difference?
also
aftermarket headunit's, i read on my metra instruction manual, they have to tap from the fuse box in order to get power because our stock headunits do not have a switched 12 volt accessory lead, does this mean when ever i turn the engine off the headunit itself will go off to?
Your help will be greatly appreciated, my date i put in my headunit is tomorrow, so any info given will be of great help.
thanks guys
Old Jan 12, 2007 | 03:27 PM
smartmlp's Avatar
I have not installed a head unit in a cobalt with the 6 speaker system so I can't speak for that. As far as taping into the fuse in the fuse box, just tap into one with Retained Accessory power. This would include the Sunroof, etc. Just make sure you tap into the side that the fuse protects.
Also, I thought the 6 speaker system had a factory external amp?
Old Jan 12, 2007 | 06:18 PM
the sub is the only thing that i saw powered, i saw a picture on here about the external amp it had.
but thanks for your help man!
when you turned your motor off, did the headunit go off to or no? cuz i still want to listen to music when accessory is on.
Old Jan 12, 2007 | 08:27 PM
smartmlp's Avatar
As I said, if you wire it to the sunroof fuse it will not go off until you open the door without the key in the ignition. If you turn the car off, remove the key, the radio will stay on, just like the stock radio.
Old Jan 12, 2007 | 08:39 PM
nhcobalt's Avatar
The install was fairly simple i also have a an alpine head unit it sounds better than the factory unit. I am thinking of puting a dvd player in soon.
Old Jan 13, 2007 | 12:32 AM
bro, you are awesome! thanks for the help man!
Old Jan 13, 2007 | 06:05 AM
EmperorJJ1's Avatar
it does... its a 6 channel 2 ohm stable amp.
Old Jan 13, 2007 | 02:56 PM
so does that screw me over?
bump?
Last edited by streetracinazian; Jan 13, 2007 at 02:56 PM. Reason: Automerged Doublepost
Old Jan 13, 2007 | 09:47 PM
EmperorJJ1's Avatar
yes and no... you will need to either figure out a way to hook up the new hu to the factory amp. if you do you will be fine. or you will want to replace your speakers.... (im not sure on the front 6.5 and tweeter but the 6X9s are two ohm for sure) 2 ohm speakers will fry a headunit thats made for 4 ohm (most are check your specs) and you will need an amp for the sub
Old Jan 13, 2007 | 11:36 PM
iLLmaTic3s's Avatar
just wire up the deck..u shudnt have a problem. hook the remote turn off the deck to the correct wire harness and your all good. it only when ur puttin in new speakers u have to bypass the amp.
Old Jan 14, 2007 | 12:05 AM
ah thanks guys for the input, i put the headunit in, only problem is the headunit goes off when the key is taken out or just clicked twice down, but oh well. sounds great, cept for the lows, almost over-powering and puts distortion at high volumes, but i like it regardless =)
Old Jan 14, 2007 | 12:36 AM
smartmlp's Avatar
Sounds like you wired it into the ignition instead of the line I told you to wire it in. If you are happy, then thats all that matters :-)
Old Jan 14, 2007 | 12:49 AM
ah **** lol, i knew i forgot something!
Old Jan 18, 2007 | 10:15 AM
EmperorJJ1's Avatar
wait so the unit turns off when you turn the car off instead of staying on for 10 mins? does it turn back on if you have the car on acc?
(sry but ive been wondering a good way to disable the whole staying on for 10 mins or dor open thing)
Old Jan 21, 2007 | 12:47 AM
yes it does
Old Jan 21, 2007 | 01:02 PM
averagewhiteboy's Avatar
Pic of the Alpine in your car?
Old Jan 21, 2007 | 02:46 PM
EmperorJJ1's Avatar
sounds like my kind of accident. thanks
Old Jan 22, 2007 | 12:40 AM
Old Jan 22, 2007 | 12:42 AM
Use [IMG] code instead.
Old Jan 22, 2007 | 12:43 AM
lol yeah, i kinda messed that one up haha
Old Jan 22, 2007 | 12:53 AM
Just post the links then instead of all that other ****. If you need me to, I'll then use [IMG] code.
Old Jan 22, 2007 | 12:56 AM
i edited the post lol so it showed up right, unless you didn't see it, or unless i effed it up again =/
Originally Posted by streetracinazian
let's hope i did this right
Last edited by streetracinazian; Jan 22, 2007 at 12:56 AM. Reason: Automerged Doublepost
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
roth
Sep 26, 2015 12:16 PM
