Really Screwed Up...
Well, I'm currently in the middle of a nitrous build on my cobalt and I was in the process of trying to locate a tachometer signal. Naturally I thought that I could source it from my gauge cluster (turns out that is not the case). I removed my gauge cluster and in the back there is a 16 pin connector that plugs in the back of it. I was probing each pin and revving the engine to try to determine which wire the signal was coming from. In my rush, I made an amateur mistake, and was using stranded wire to probe each terminal because my voltmeter probe was too large to fit inside the connector. I was placing the wire in one of the ports and one of the strands came off and I shorted between two terminals.
Afterwards I found the following systems to no longer function:
-Cruise control
-DIC (little screen in the gauge cluster, buttons on dash non responsive)
-CEL
-HVAC (fan works, will not control temperature)
-Three buttons under fan control (A/C, defrost, recirculate)
-Heated seats
I went and bought the factory service manual in PDF form that has all the wiring diagrams for the cobalt. It looks like I shorted between the "computer lines data system" which is tied to the BCM and PCM.
Anyone do this before? I am concerned after reading up on replacing the BCM that I will be forced to go to the stealership and get royally raped.
The most ironic part was that I was trying to install systems that were going to protect my car, and in the end it was what ended up breaking it....
P.S. - If anyone wants the service manual I would be happy to share it. Help in return would be appreciated.
-Cruise control
-CEL
-Heated seats
The systems you were going to install didn't end up breaking it, negligence did. If I were you, start checking fuses like ^^^ said. And trace those wires back to the relay. Might have fried several things with that stunt lol.
That sucks but if you shorted out the data connections you might have fried out the BCM and your stuck replacing it, also hope you didn't damage the PCM because that would be expensive. Next time get a tach signal from an injector or a coil pack. Also BCM isn't hard to replace.
The BCM looks insanely easy to replace, however apparently it is a nightmare getting the proper part (because there are multiple part numbers / they modified that part between years). Also apparently the dealer has to flash it for some reason with a proprietary deal? Ever swapped one?
I would much prefer if it was all isolated to the PCM. I can grab one off ebay for $25. I have a Trifecta tune, so reflashing is a breeze. I am having a little confusion since GM uses the same computer in a large amount of cars and there are two numbers on th PCM. There is a part number and a "serv" number. I'm assuming one is a hardware number and the other is a software #. Just need to be 100% sure which one I need to match, drop the PCM in, flash it, and I'd be good to go.
I'm glad to hear it was a fuse! Yea I've replaced a few BCMs for friends and the dealer has to flash mainly for the RF ID off of your key. I work at a stereo shop and two of my cobalt buddies said they could do their own remote start/alarm install and ended up messing stuff. So instead of just the remote start I had to help them fix their mistakes and install their alarms; But hey, you live and you learn.
Sent to EmperorJJ1@gmail.com
importkiller
Sep 30, 2015 07:18 PM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
