Remote Starter Question
Old Jun 24, 2007 | 12:58 PM
  #76
ptrblkz24's Avatar
Originally Posted by smartmlp
These systems are not worth the cost savings. When you use these, you are effectively disabling the factory built in theft support. With this, a thief can come along and pop the key tumbler and just start the car.
Get a CAN interface module, not only is it much better, it makes installation a breeze. They interface directly with the computer and your alarm wires to it instead of going directly to the cars wires. Saves time, looks better, and is alot safer. idatalink is a good example of a CAN bus interface module.
As for the starter only working sometimes, I have no idea where the problem would be since I dont know how the installer installed it. The ignition in these cars is different then most, as the computer starts the car and not you when you turn the key. You will have to take it back to who ever installed it and ask them, most of us here cant help because there is so much that could be going wrong or setup wrong and we don't know the details of how it was installed.
Your not disabling the factory theft system.It still needs a signal from the alarm to activate it.You make it sound like if you take a screw driver and stick it in the ignition switch it will start.It wont.Sure,you have to put a spare key in it.If your worried about someone breaking in and using the spare key to steal the car,Break the head off and make it useless.Im not worried about someone stealing my car.If they want it,they will get it.Its not like there gonna watch you go to your car and see if you have a remote start,lol.I agree with you though on the idatalink.There def the best on the market.Whatever you do,stay away from dei bypasses,there garbage.
As for the car not starting,i dont know.All i know is that he fucked up somewhere.
Old Jun 25, 2007 | 12:53 AM
  #77
huntingparty's Avatar
Originally Posted by ptrblkz24
You dont need those bypass with the doorlock interfaces and ****.Just get this,and your done.Its only 20 bucks.
Just put a spare key in it,and call it a day.Its a universal transponder bypass kit.
This is only half of the cobalt's security, it also uses passlock 2 in conjunction with the transponder key. You have to bypass both to make it work.
Old Jun 25, 2007 | 01:11 AM
  #78
djblass's Avatar
how about a clifford alarm how are those alarms
Old Jun 25, 2007 | 03:06 PM
  #79
ptrblkz24's Avatar
Nope,thats all you need to bypass it.
There good alarms.Alittle on the pricey side though,depending on which model and options you get.
Old Aug 14, 2007 | 05:01 PM
  #80
wdsoccer's Avatar
im goin to get my remote start fixd this week. the ass hat that installed it didnt even do the alarm
Old Aug 16, 2007 | 12:39 AM
  #81
wdsoccer's Avatar
i made a list of **** the guy didnt install when doin my remote start. he didnt do the alarm, dual shock stage sensor, remote paging system, valet mode, and turbo mode (for next summer when i turbo)
Old Aug 17, 2007 | 03:57 AM
  #82
EmperorJJ1's Avatar
i would be pissed
Old Sep 25, 2007 | 12:07 AM
  #83
wdsoccer's Avatar
i took it back and they used the bypass. everything works great now
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
