UPDATED General Stereo FAQ - READ THIS!
Old Sep 20, 2009 | 08:15 PM
  #151
killah18's Avatar
hey for the for the Cobalts with the Pioneer system. What are the speakers located near the edge of the windows on the doors called?
Old Sep 30, 2009 | 08:03 PM
  #152
JL-KA's Avatar
Uhm...tweeters?
Old Sep 30, 2009 | 08:12 PM
  #153
jsepulveda's Avatar
If you dont care about messing up the factory speakers on the non pioneer speakers, you can do what I did, which is break all of the plastic connectors off the back which hold the speaker to the bracket then cut the gasket part of the speaker with a razor knife so that a new speaker can be installed with the factory brackets. Then drill holes around where the gasket was since theres a lip that runs around. I have 5 1/2s up front, so they fit perfectly inside where the speaker sat, but 6 1/2 will also work, just need long enough screws to reach to the where the speaker gasket was. Definately steer away from hardwiring head units in though, did that on mine and the computer started messing up, crappy gas mileage, running real rough, installed the factory one back in and it was good as new.
Old Oct 27, 2009 | 07:18 PM
  #154
cobaltss4u2env06's Avatar
okay so i have a 06 ss/sc with the pioneer system, xm, but no onstar. i want to buy the pioneer 4100, keep the factory speakers but also add an extra sub and amp. i no i need the dash kit for the double din. and i need the antenna adapter. but what else? which wiring harness do i need that keeps my steering wheel controls, door chimes, etc? and then which one would i want if i dont care about the door chimes?
Old Nov 7, 2009 | 04:06 PM
  #155
slobalt08's Avatar
Stupid question, but does installing an aftermarket HU disable theft deterrent? Also I know the radio has something to do with the Passkey 3 system, so will I need the dealer to do a relearn or something?
Old Nov 13, 2009 | 01:48 PM
  #156
black110's Avatar
oh i havent had a chance to update the thread but if you decide to do it go with the 70-2104 instead of the 70-2202
Glad I just read this because I was just about to buy the 70-2202... I have an 07 Cobalt LT with factory HU, no Pioneer, no onstar. So I should also go with the 70-2104? Is it just "plug and play"? Thanks for your help!
Old Nov 14, 2009 | 12:30 AM
  #157
EmperorJJ1's Avatar
correct... the 2104 didnt come out until after the 2202 and after i lost the ability to edit the first post
Old Nov 22, 2009 | 04:39 PM
  #158
black110's Avatar
Ok, so I got the Metra 70-2104 harness and have it all hooked up except for the red power wire. I was trying to wrap it around the windshield wiper fuse (as recommended) and I can not find a place to run the wire through the firewall! Is there a fuse somewhere in the cab I can hook to or can someone tell me where I am supposed to run the wire through the firewall at? Again, thanks in advance for your help!
Old Nov 23, 2009 | 06:59 AM
  #159
EmperorJJ1's Avatar
the wiper fuse is on the inside fusebox thats like 18 in from the radio
i wouldnt recommend wrapping the wire around the fuse thou
Last edited by EmperorJJ1; Nov 23, 2009 at 06:59 AM. Reason: Automerged Doublepost
Old Nov 23, 2009 | 01:15 PM
  #160
black110's Avatar
I went out to the car and tried to locate the wiper fuse that is inside the car and could not find it. On the left side of the footwell in the passenger side theres a panel with a vent and a little symbol (possibly a lightning bolt symbolizing a fuse box?) so I tried prying on the panel a little and couldn't get it off. I didn't pull too hard b/c I didn't want to damage the panel. Is the fuse located behind this panel and if so, do I just pull and pull til the panel pops off or what? I was originally going to have the local car audio shop install it but they said they will not install it unless I have the Lan harness otherwise I would have already taken it to them. Thanks in advance for your help and sorry for all the noob questions...
Old Nov 23, 2009 | 01:25 PM
  #161
hungryhip-ccp's Avatar
yes, very nice write up and very very helpful. Thank you.
Old Nov 24, 2009 | 01:37 AM
  #162
EmperorJJ1's Avatar
yup the fuse box is right behind there.. there will be 2 clips on the bottom one on the top and 2 slider things at the top as well. SO your going to want to yank the bottom first. then the top left corner. It feels like ur braking it because its not secure so there's alot of flex but the clips are still tight
once u got the clips out slide down and ur done
Old Nov 27, 2009 | 07:02 PM
  #163
kingg5's Avatar
im puttin in a avic D3 next week...where do i plug the vss wire into?
Old Nov 28, 2009 | 12:22 AM
  #164
EmperorJJ1's Avatar
hopefully ur car is an 07+ then the module harness metra makes provides the VSS
Old Nov 30, 2009 | 04:14 PM
  #165
kingg5's Avatar
nope its an 06, sig even says so lol. its all good tho, i got it done. works flawlessly, i cant belive people pay money to have this done.
Old Dec 2, 2009 | 03:12 PM
  #166
deereclaasman's Avatar
Hey does anyone here have a pioneer system (tweeters, sub and everything) that would sell it, or tell me where to get it? Is it possible to add the pioneer system to my LT without changing the HU and everything? Chevy dealer doesn't know a damn thing about it. Thanks!
Old Dec 3, 2009 | 12:04 AM
  #167
ThiZo_19's Avatar
hey guys, i have a 05 ss sc with the pioneer 7 speaker soundsystem...sounds nice but no eq curve man its depressing....so i wanna add my p4000dvd do i absolutely need a harness, cant i just splice into the wires??? im a mechanic i wire things all the time...itsno problem i just cantfind my diagram on ondemand, shop key and all data WTF?. has anyone spliced without a harness. also i will remove stock subwoofer, and run my 2 mtx's seperatly from the output behind my AFTERMARKET HU. please guys someone get back to me thanx!
Old Dec 3, 2009 | 01:28 AM
  #168
EmperorJJ1's Avatar
you can thizo but 05-06 is the cheap harness so i would just spend the cash and get it. You will need to get acc from the fuse box regardless
i wouldn't do it if i was you... without the amp the 7 speaker system wont work. and unfortunately there's no wiring for it in the non pioneer cars. So you really cant just add the amp correctly. By the time you wire it up and get it working you could have spent the same amount on aftermarket equipment and had better results
Old Dec 5, 2009 | 02:15 PM
  #169
ThiZo_19's Avatar
[QUOTE=EmperorJJ1;4497640]you can thizo but 05-06 is the cheap harness so i would just spend the cash and get it. You will need to get acc from the fuse box regardless
Thanx jj ur the bossss!, where can i get this kit man i see all sorts on ebay but iunnoif i should trust it, i figure if i buy a harness it better be Plug and plag man! lol power is fine ill get that **** from my wiper motor b4 it being fused obviously...once again emperor thankyu for ur quick responce
Old Dec 6, 2009 | 10:41 PM
  #170
EmperorJJ1's Avatar
ebay best buy local shop wherever... just make sure its the light blue one not the gray one
Old Dec 26, 2009 | 12:08 AM
  #171
richienolan's Avatar
so im new and just wnated to get this right 06 ss/sc with pioner and on star i dont care about the on star so with the metra 70-2103 and i run a fuse tap the factory subs will still work correct and if down the road i want to add subs i can just use the pre outs on the aftermarket hu and wire my own ame and all that good atuff thanks for all the help so far i love this site its so help ful
Old Dec 27, 2009 | 10:16 PM
  #172
EmperorJJ1's Avatar
yup u got it man
Old Dec 28, 2009 | 02:29 PM
  #173
thanks for every thing
Old Dec 28, 2009 | 06:00 PM
  #174
05cobaltblue's Avatar
Hi,
For my daughters 05 base sedan with the base radio,no XM, no Onstar. I was wanting to install a Peripheral harness for an Ipod interface. During the process I found that the base radio does not have a 12 pin connector, only a 24 pin. Do you know of any other options, or is an aftermarket HU with a USB my best option? Which harness for just a 24 pin? Thanks
Old Jan 1, 2010 | 03:32 AM
  #175
EmperorJJ1's Avatar
i dont think they make one for the 24 pin. all the ones ive seen have the 2 plug. the main plug is for the radio and the secondary one is for the xm going to the back. the module just makes the HU think the ipod is the sat radio and it thats how it works. If you dont have that second lil square plug then there isnt anything u can do with that radio.
Like i said every 05-06 one ive seen has 2 plugs (not nessicarily wires or the plugs in the car but the 2 ports on the back of the radio)
