UPDATED General Stereo FAQ - READ THIS!
Old Jan 6, 2010 | 07:59 PM
  #176
05cobaltblue's Avatar
Thanks again for the help,
I purchased an aftermarket HU, The harness has 8 speaker wires, then:
yellow - battery lead
red - acc power
black - ground
orange- unknown/not used
orange/white - unknown/not used
blue - unknown/not used
other than the unused wires, using the Metra 70-2103 will more or less match wires correct?
How do I pull power, by running the yellow wire to a power source?
Old Jan 7, 2010 | 03:12 AM
  #177
EmperorJJ1's Avatar
orange & orange white just cap off so they dont touch anything. If you have the pioneer system then you will need to hook up blue to the 70-2103 to turn on the stock amp. If not then cap it off so its not touching anything
ACC or red is the one not in the car. you will need to run the supplied wire to the fusebox with an add a fuse or fusetap
Old Jan 7, 2010 | 04:38 PM
  #178
Thanks,
so I guess the yellow will match up to a yellow in the metra harness.
Old Jan 11, 2010 | 03:17 AM
  #179
EmperorJJ1's Avatar
yup.
Old Jan 11, 2010 | 12:58 PM
  #180
stoon_cobalt_colby's Avatar
hey guys i got a question i cant find the cheap harness for my 07 with the xm and 6 cd changer one can someone send me a link? the only thing i will lose by using a cheap one is my door ding and signal sounds?
Old Jan 11, 2010 | 04:09 PM
  #181
EmperorJJ1's Avatar
right the only thing u loose going from the 2 harnesses is the door chimes. you also loos steering wheel controls and xm going aftermarket
http://shop.ebay.com/i.html?_nkw=met...2104&_osacat=0
Old Jan 11, 2010 | 05:59 PM
  #182
thanks man much apperciated now what does u guys suggest for a indash budget isnt very good but ill see what i can do
Old Jan 11, 2010 | 06:52 PM
  #183
EmperorJJ1's Avatar
pioneer 3100dvd
Old Jan 23, 2010 | 10:39 PM
  #184
vash90909's Avatar
I have a 08 ls without pioneer and onstar. I got the 70-2202 and of course a aftermarket hu. Out of the hu is yellow, black, red, orange/white, blue/white, grey, grey/black, white, white/black, purple, purple/black, and green, green/black. I hooked them to the same color on the metra 70-2202 and plug the metra to the factory harness. I still have a orange only wire left from the metra. When I turn on the car nothing happens. What's wrong?!?!?
Anyone know?
Old Jan 25, 2010 | 02:10 AM
  #185
EmperorJJ1's Avatar
red wire isnt in the harness u have to run a seperate ACC to the fuse box
Old Jan 25, 2010 | 02:22 AM
  #186
hey do u guys know if a 10 kicker comp will fit in stock pioneer sub box
Old Jan 25, 2010 | 03:27 AM
  #187
EmperorJJ1's Avatar
i know a 10" kicker comp will not fit in the stock box... someone has tried it before
well unless u install spacers or something
Last edited by EmperorJJ1; Jan 25, 2010 at 03:27 AM. Reason: Automerged Doublepost
Old Jan 25, 2010 | 03:47 PM
  #188
k thanks man
anyone know how to remove stock sub? i got box and everything out but the sub wont come out is there a trick?
Last edited by stoon_cobalt_colby; Jan 25, 2010 at 03:47 PM. Reason: Automerged Doublepost
Old Jan 25, 2010 | 03:56 PM
  #189
EmperorJJ1's Avatar
did u take out the screw on the back? its just those screws on the front the one on the back and some foam tape (so takes a lil bit of elbow grease to pull out)
Old Jan 25, 2010 | 08:07 PM
  #190
never seen that screw took it out it pretty easy to take out dam u were right the kicker comp doesnt fit gonna have to mod my box thanks man
Old Feb 1, 2010 | 12:43 AM
  #191
thebucky84's Avatar
sooo, any ideas on how to make a cd player fit? mine sticks out a bit, its that damn bracket in the back thats stopping it. Is it safe to dremel that, it seems like the heating/ac ducting runs behind it. any input or how to on this would be great!
Old Feb 1, 2010 | 01:06 AM
  #192
EmperorJJ1's Avatar
cut the plastic out and remove the metal bracket. most of us have done it
Old Feb 1, 2010 | 04:55 AM
  #193
slobalt08's Avatar
Alright here's where I'm confused. Is this for 05-06 only? Because I didn't fuse tap any wire. My GMOS Lan 04 has a red wire, and I connected it to the red wire on the hu, and it works fine.
Secondly I'm confused with these two wires below. Where do I connect them? My hu doesn't have these color wires, unless their different color wires on the hu.
"2. Connect the blue/pink wire to the VSS or speed sense wire of the aftermarket navigation radio."
"3. Connect the green/purple wire to the reverse wire of the aftermarket navigation radio"
And lastly, I don't get what they mean with the black/yellow wire. Do I just connect it to the ground wire? What do they mean about tapping?
Old Feb 2, 2010 | 12:59 AM
  #194
thebucky84's Avatar
ok cool, and it doesnt hurt any structural integrity for anything back there?
Old Feb 10, 2010 | 06:26 PM
  #195
JayBoo's Avatar
Ive looked through several pages.. The sites so slow its finally killed me.. I have the 06 SS/SC without onstar.. pioneer sound system blah blah lol. I need to know the minimum I have to buy to get an aftermarket deck to work. Local shops, crutchfield and best buy tell me I need a harness thats 170 dollars(90 from crutchfield) to get it to work. I look at the harness on crutchfield and the harness has the DIC underneath the stereo... I dont need that do i? my DIC is underneath the tach. Cant I save myself the hassle and just get:
http://www.crutchfield.com/p_1272RGM...n-Adapter.html
(60 dollars through crutchfield)
and the deck and thats it? well it comes with:
http://www.crutchfield.com/p_142GM15...eiver-Kit.html of course so you know what I mean.
Old Feb 11, 2010 | 01:31 AM
  #196
EmperorJJ1's Avatar
http://www.crutchfield.com/p_1207021...&ssi=0&tp=2977
Old Feb 11, 2010 | 01:01 PM
  #197
JayBoo's Avatar
So youre saying I dont need those super expensive adapters? Just that?
Old Feb 12, 2010 | 02:10 AM
  #198
EmperorJJ1's Avatar
yes that's the wiring harness u need. the kit u posted is the one u need as well. then get a gm antenna adapter
Old Feb 12, 2010 | 02:30 AM
  #199
hey guess i recently hooked up a electric cross over to run amps and speakers just wondering why when i hook up my rear speakers to the crossover it makes a loud buzzz noise
Old Feb 12, 2010 | 02:33 AM
  #200
EmperorJJ1's Avatar
ground loop maybe? x-over broken? cant u just use the crossovers in the amps?
