Weird sound from radio
Old Sep 8, 2013 | 08:58 AM
Olivier12444's Avatar
Hi, I'v had a Pioneer AVH-P4300DVD for 2-3 years now. I recently reajusted the equalizer and I noticed that when I raise the 2.5kHz, 8kHz and 10kHz frequencies, I get a weird "shhhhh" sound from the speakers... What's the cause? Bad ground? Thank you!
Old Sep 9, 2013 | 03:35 AM
EmperorJJ1's Avatar
what do you mean? when you raise them does it happen just when ur adjusting the eq? or all the time? or just with the beat?
do you have the base or pioneer system? any other aftermarket parts?
Old Sep 10, 2013 | 09:49 PM
It occurs when the 2.5kHz (or upper frequencies) are raised to 6dB or more. For now, it's on 4dB and the noise is almost imperceptible. And the sound is all the time, not just on beat. Also, I have a Pioneer HU (AVH-P4300DVD) and Pioneer 6"ž component speakers in front and 6"x9" rear speakers and a Bazooka subwoofer. No amplifier for speakers.
Old Sep 11, 2013 | 02:42 AM
EmperorJJ1's Avatar
which harness are you using for the radio and do you have the base or pioneer system?
you probably should try the pioneer pico fuse fix of grounding the RCA's and see if it still does it
Old Sep 11, 2013 | 06:30 PM
I don't remember the exact model number of the harness I use, but it's the one with the box that keeps factory chimes and other wonderful ***** of GM. I had the base system. And I've got no amp powering the speakers... Does hot swapping the RCAs of the sub can do the same problem?
Old Sep 12, 2013 | 01:36 AM
EmperorJJ1's Avatar
try the pico fuse fix if not it might be the harness
Old Sep 12, 2013 | 04:10 PM
Ok thanks!
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
agentirons
Oct 16, 2015 02:11 AM
jimbofug007
Oct 2, 2015 12:06 PM
