Forced Induction Turbos/Superchargers
06 SS Not making boost
Old Aug 24, 2018 | 02:52 PM
Mkh1337's Avatar
Title says it all, I had to swap my one headlight out and in the process discovered my air filter was rusted to hell. Swapped the filter, cleaned the MAF and throttle body, put it all back together and all was fine. Two days later the car wouldn't make boost, gauge hits 0psi and wont go past it. I know the stock gauges aren't great but the decrease in power is absolutely noticeable, especially driving uphill. Tried the boost bypass mod thinking the bypass valve might be stuck open and it made no difference. The car is stock other than a weapon R cold air intake (replacing with zzp soon) , 1 step colder plugs, and a catback. The car did have idle issues after getting gas that I traced back to the evap purge solenoid which has since been replaced and solved that issue. The car has never had boost issues before other than never hitting more than 10psi, its like cleaning the MAF/TB and the new filter flipped a switch. It isn't throwing any codes. I'm stumped and have no clue what to try next.
Old Aug 24, 2018 | 07:17 PM
Mkh1337's Avatar
Update; found two cut wires on the MAF plug that had just been twisted back together and taped, soldered them and had no improvement. Swapped the MAF out with a brand new one I had laying around and still no improvement. I’m ready to push the car off a cliff
Old Aug 24, 2018 | 09:31 PM
Flarfignewton's Avatar
Did you open the throttle body by hand when you cleaned it? You may have damaged the throttle body if you manually opened it as they are not designed for that. Also did you remove the throttle body? I would check that the throttle is working normally and check for any leaks in the intake tract and vacuum lines to start.
Old Aug 25, 2018 | 12:18 AM
Sharkey's Avatar
how are you scanning it for codes? are you able to watch a data stream? if you can id have a look at the tps readings, should go to around 88% at full throttle. ive heard of these things having throttle body issues and they only open part way and that causes the lack of boost.
Old Aug 25, 2018 | 09:36 AM
Mkh1337's Avatar
Throttle body was removed before being cleaned and the butterfly valve itself wasn’t manually opened, just lightly wiped with a paper towel to loosen up the gunk after spraying with TB cleaner. I have a BlueDriver scanner that does have limited data logging, I’ll check it out and see if I can find tps through it. I haven’t been able to find any leaks manually but haven’t smoked it yet. The car revs normally leading me to think it’s something other than the throttle body, I want to think in the worst way that there’s a boost leak somewhere - but there really aren’t many places for it to leak.
Old Aug 29, 2018 | 10:18 AM
Mkh1337's Avatar
Update: logged the TPS driving around town and it’s hitting 87-88% at WOT, MAP is reading 105-109 kPa at WOT
Old Oct 13, 2018 | 04:11 PM
Mkh1337's Avatar
Bump - car has been sitting for a month and a half now as this makes it completely undrivable. I’m open to any ideas or insight anyone may have
Jordan Clayton
Jun 21, 2017 05:09 PM
Deerslayeer1991
Jul 29, 2015 11:17 PM
MyCobaltGetsMeCooter
Jun 5, 2009 07:57 PM
Jun 4, 2009 10:55 PM
fzn14
Oct 22, 2008 03:28 PM
