2.2 turbo finished
yeah no prob just dont want you to say something and then have some asshat on here call u a idiot or something
and yeah for a 2.2 a nice mitz style/size should go great
i mean yoiu are looking for a good street driven car right
well a 60 trim would provide lots of lag and im sure you want fast spool which a 60 trim wouldnt provide
Spool is based on the turbine trim, not the compressor trim, as I understand it.
I do know that the bigger the compressor wheel the more drag it will cause and the harder the turbine has to spin to create boost....
Hope this all makes sense.....
well i know those guys that made the kit wouldnt match up so a big turbo i mean a 60 trim is very very close to a pt67 which is very common on a supra and i think we can all agree that you arent putting anything like that on your car
Ya.
I know it will be fine. It will give me good out put, I know it. It will be fine.
I can't wait! Another day down. Only 2 more, at the most, hopefully. Hopefully It was shipped out today.
I would not see any reason why it was not. Heck, I have called John so many times that I am sure he wants to get it out so I don't keep calling him about it...
You can see all my questions here about the map and see the map!:
http://**************/viewtopic.php?t=923&highlight=
Last edited by 2.2ionjentzsch; Apr 16, 2007 at 01:06 AM. Reason: Automerged Doublepost
My engine is being pulled right now for the following:
Eagle Rods
Diamond Pistons
ARP Head Studs
Stg 2+ Clutch
Cometic Head Gasket
Should be re-tuning monday.
Then 60lb injectors will be replacing the stocky's and some turbo cams to add.
Projected 300-350WHP @ 15-20psi. (I know the turbo will hold 20 no problem)
Eagle Rods
Diamond Pistons
ARP Head Studs
Stg 2+ Clutch
Cometic Head Gasket
Eagle Rods
Diamond Pistons
ARP Head Studs
Stg 2+ Clutch
Cometic Head Gasket
Eagle Rods
Diamond Pistons
ARP Head Studs
Stg 2+ Clutch
Cometic Head Gasket
You suck!
so Trevor finally got his turbo kit! now we can see how the stock kit runs agains a moded kit!
http://**************/viewtopic.php?t=250&highlight=
not at first, but i did get a 3inch exhaust put on. I put that big of an exhaust on because im rebuilding the engine.
by the 30th i should be fully tuned and running down evo's and sti's. im just not looking forward to the damn 1k break in period of the pistons/rods. not sure how im going to keep the car out of boost during that time, maybe just keep it under 2300 rpms to start and not have a lead foot lol that would suck for 1k miles.
