Forced Induction Turbos/Superchargers
Alcohol/Methanol/Water Injection Q&A...
Old Sep 23, 2007 | 05:31 PM
  #51
WSFrazier's Avatar
We have a knock sensor. Your car won't go boom because you run out of meth.
Old Sep 23, 2007 | 05:43 PM
  #52
hg_5's Avatar
So we can run the meth without tuning right? Just for the cooling properties, and just a tad of hp?
Old Sep 23, 2007 | 06:51 PM
  #53
WSFrazier's Avatar
Yes. To take full advantage you will want tuning, but it won't harm anything.
Old Sep 23, 2007 | 08:04 PM
  #54
freakta's Avatar
ok ill try again. are there any negative side effects with the car when meth/water injection?
Old Oct 22, 2007 | 08:26 AM
  #55
Ultimate CC's Avatar
Sorry I wasn't getting emails when replies were made...the negative effects are only when you are running too rich which is only an issue if you don't get tuned properly, if something happens and flow of injection stops and you don't have a failsafe or something to protect your motor and thats about it...it will give you a clean carbon free motor producing more power safely...
Old Oct 22, 2007 | 08:45 AM
  #56
lsjwannabe's Avatar
Originally Posted by WSFrazier
Some info I thought I would toss out.
Spraying after the blower is more efficient, but you don't get the cooler blower. IMO I would get 2 smaller nozzles and have one before and one after. Right now I got 2 spraying after and going to try routing one of them into the intake.
Also, water actually lowers the temps better than meth. Meth is used for added fuel. 50/50 mix is optimal to get the best of both.
interesting.... which kit are you using tag's? I think im going to go with devils own but i may like this set up you speak of
Old Nov 1, 2007 | 06:17 PM
  #57
bump for answers...
Old Nov 12, 2007 | 11:08 PM
  #58
Superchargimus Prime's Avatar
does anybody have the GM Stage 2 tune w/ 2.79 pulley and a meth setup? if so, what kind of gains, or if not, will the stage 2 tune help w/ the meth since it's already a little rich?
Old Nov 21, 2007 | 09:15 AM
  #59
bump for an answer...one thing to note is that you will need to be tuned for the meth, the gm stage2 will not be sufficient...
Old Dec 1, 2007 | 02:50 PM
  #60
bump for life
Old Dec 1, 2007 | 03:08 PM
  #61
widebody_balt_ss's Avatar
hey guys, I have not read through this entire post however I just got my AIS kit in yesterday and will be installing it with before and after dyno numbers in a few weeks.
I have seen a few questions that have been asked without any awnsers. I have been talking with Rhdney at Alcohol Injection Systems.com for a week or so and did order thier stage two kit.
as you can see in the pictures all of the parts are excelent. ALOT better looking than I thought they were going to be. I got steel braided lines with mine as well. he is also offering a metal bracket I belive this week..
as far as the question about running with spray. you would be dumb not to. you are leaning out your air fuel ratios with the nitorus, and you are adding points of octain with the meth. why would you not? with this set up i will have no knock what so ever. it allows for much better tuneing. colder intake and supercharger temps. al around safe product. I wish I would have been educated a long time ago about this. it would have been one of my 1st mod's without question. sorry about the book, but im prety excited about this.
also wanted to let you guys know. if you have any questions at all. just call AIS. if I didint sell you on this, I know Rodney will. he is great, he even included a buisness card in the package and told me if i had any questions at all to give him a call at any time. all of his systems also come pre made and tested before they even leave the building. pre wired and everything. It also comes with a booklet of instuctions. with pictures and everyhting. trust me, you cant go wrong with this setup.
Last edited by widebody_balt_ss; Dec 1, 2007 at 03:08 PM. Reason: Automerged Doublepost
06blackg85ss
83
Jan 18, 2017 04:35 AM
SlowSaturn
Sep 28, 2015 11:03 AM
roadrunner132
Sep 16, 2015 09:13 AM
Bluelightning
Sep 8, 2015 05:18 PM
Macgyver2484
Sep 2, 2015 05:44 PM
