BLAZIN07SS's revised turbo build!
I'm too JDM for you
I'm too JDM for you
got quite a bit done today as far as teardown is concerned.
installed:
-2.2 tensioner
-2.2 alternator and wiring pigtail
-hahn intake manifold
all the SC stuff is out, along with the stock heat exchanger and IC pump
the last time she will be SC'd
hahn mani
installed:
-2.2 tensioner
hahn mani
I'm too JDM for you
ignore the TERRIBLE red couplers, have black ones on order.
i want to really thank all the locals that came out and helped with everything. i really appreciate it
I'm too JDM for you
not ready to fire yet. just little BS to tie up.
wideband
hot side pipe
egt into manifold
valve cover and cut stainless lines for the breather set-up
and thanks! i need to tidy up the bay a little more and get a real intake
wideband
hot side pipe
egt into manifold
