Forced Induction Turbos/Superchargers
Garrett 2.2l Turbo Kit
Old Apr 21, 2011 | 01:38 PM
  #51
terry11's Avatar
Um. they won't? Your making this seem WAY harder than it actually is
Old Apr 21, 2011 | 04:00 PM
  #52
flyy's Avatar
sorry
Old Apr 21, 2011 | 04:47 PM
  #53
jmesl8er's Avatar
where r u located. i work in a machine shop, got a million tap sets, i could have that pan done for u in 5 mins. free of charge too
Old Apr 21, 2011 | 05:05 PM
  #54
flyy's Avatar
i live in england so id have to send it to you
Old Apr 21, 2011 | 05:13 PM
  #55
jmesl8er's Avatar
Thats a pretty far walk. Nobody on here can really explain how easy it is to tap something. Its as easy as screwing a bolt into something, thats basically what a tap is, a sharp threaded bolt, literally take 5 minutes to do. Search youtube, ton of videos of people tapping ****
Old Apr 21, 2011 | 05:38 PM
  #56
flyy's Avatar
alright ill check out youtube
Old Apr 21, 2011 | 05:42 PM
  #57
flyy's Avatar
i lloked and there are no youtube vids on how to tap it but its just a bolt with really sharp edges that you drill into the oil pan and it makes threads for an oil feed connecter?
Old Apr 21, 2011 | 08:26 PM
  #58
jmesl8er's Avatar
Here you go
YouTube - How to tap steel | tapping steel | ultimatehandyman
Old Apr 21, 2011 | 09:14 PM
  #59
terry11's Avatar
This guy is honestly helpless. You can take it from here bud lol
Old Apr 21, 2011 | 09:27 PM
  #60
jmesl8er's Avatar
If you can't take anything away from this video, have a professional put the entire kit on your car
Old Apr 21, 2011 | 09:50 PM
  #61
flyy's Avatar
I appoligize if I want my **** done right the first time, next time keep your negative comments to yourself please.
Old Apr 21, 2011 | 09:52 PM
  #62
terry11's Avatar
You can't expect to be spoon fed every single little tidbit of information. Think a little bit on your own
Old Apr 22, 2011 | 10:34 AM
  #63
busa4's Avatar
instead of tapping it you can have it welded on. thats what i did. if your willing to ship it to me in tampa, fl i can weld it on for you but im pretty sure you could find someone near you that can weld aluminum.
Old Apr 22, 2011 | 11:21 AM
  #64
Take2-08LT's Avatar
For those of you with this Turbo. Where did you run your coolant supply and return lines? Also will any of the galley plugs work work for the oil feed? (Meaning can I use a plug on the backside of the motor or do I have use one up front)
Old Apr 22, 2011 | 03:56 PM
  #65
busa4's Avatar
you can tee off the coolant lines going into the firewall for the heater core
Old Apr 22, 2011 | 04:42 PM
  #66
PsychoCam's Avatar
any of the rear oil galley plugs will work fine for the feed. I am using the rear galley plug closest to passenger side under the turbo manifold for the feed.
the coolant lines are teed to one coming from the heater core and my other coolant line is going to the line to the coolant res tank
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
