View Poll Results: Which companies turbo system & exhaust should I go with?
Hahn
74
54.81%
ZZP
61
45.19%
Voters: 135. You may not vote on this poll
Hahn or ZZP?
hahn and zzp are like apples and oranges. zzp is my vendor of choice with blowers... there twincharged kits are nasty as hell. i havent met anyone with a zzp tune for the ss/tc. only hahn and trifecta i seen and hahn was always on top between them 2. reliability i say zzp.
what a bunch of haters you guys are!!! You will never see anyone from hahn talk about your co this way... WTF
this is all i have to say.... let the people decide...
HAHN FTW
major mods: HAHN LEVEL 5+
60lb inj
7gph meth @ 5psi (100% M1)
3in intake with 5in K&N
gasket port matched exh side on head
78lb springs
9:5:1 diamond
3in high flow cat
3in exh crush bent
38mm ext vented to atmosphere
tuned to 22.5 holding 21psi till 7800rpm
91oct pump gas
afr starts at 12.2 working to a 11.5 by RL
12-14* timing
other mods:
stock clutch lol (in one vid you can see i lift on the 1-2 cause it slipped hard)
235/40/18 BFG KDWII
stage 1 axles
HAHN FTW
60lb inj
78lb springs
9:5:1 diamond
3in high flow cat
3in exh crush bent
91oct pump gas
12-14* timing
other mods:
235/40/18 BFG KDWII
stage 1 axles
luv u 2...
way slower? and you basing this off of? you guys are HATERS! i deal with em daily :shrug:
post a reply with vid of inside, and a mod list if your gonna act like you got something to prove.
lsj turbo, not twincharged. not stroked.
all this talk and yet hahn is still ahead by more than a few...
