110 octane gasoline
I'm catless right now and the o2 sensors are turned off to prevent the cel from freaking out.
That sort of depends on the specific race fuel. Sunoco and VP lines for example both carry leaded and unleaded versions of their race fuels that wear the "for off road use" labels. The fact that it's an oxygenated is the only reason it's labeled for off road use only with the unleaded versions.
if you cant afford a retune for gas in your area why the hell are you worried about a new tranny and e85 and a retune then. you wont be able to afford that then either. if you have 3k get your car running right now. youre gonna be on that 4.45 list for awhile. you can save the money back up.
I've read that so many times on here. If $200 for a retune breaks your emergency bank then you're doing something wrong. I would never put myself close to not being able to get through an emergency for the sake of my car. Honestly bite the bullet and get it tuned. In the long run it'll cost you the same anyway.
Hacksawing **** like a tune and mixing fuels is not the proper way to go about this with a big turbo car.
If you can't afford the retune save money and don't drive it. Walk, take the bus whatever. Don't bitch and moan about you "need" a car when you have a $2000 turbo you aren't willing to run properly.
Gotta pay to play and you should have your "ducks" in a row before doing anything this big to a car.
OP, despite you being cat-less you still cannot run leaded fuel because you are actually still using an 02 sensor (technically its an a/f ratio sensor but whatever). The only thing done in your tune is the computer not turning on the cel when a P0420 is thrown due to your rear 02 sensor switching because you have no catalytic converter
I own HPT so it's cheaper for me. Either way like everyone else has said you shouldn't be throwing loads of $$$ at go fast parts if you can't afford to run them right. Seems like your priorities are a bit off. It'd be a shame to cause some damage because you half-assed it.
Very true but we don't know if the gas being brought up in this discussion is actually leaded or unleaded. I seriously doubt it is leaded due to the fact that you can buy it at a pump on the street but who knows.
Dude I'm not trying to be a dick. I'm just saying don't skimp. I'd hate to see something go wrong because of a few hundred $$$. Especially after you dumped a ton of $$$, time and work into it. I've seen small builds go boom because of a bad tune.
Ok, kool. Thanks for the concern then. Sorry but way too many trolls on here so I thought u were one of them. Anyways, yea I know I should tune the car asap but like I previously stated, I can always get the tune whenever, whereas the tranny is only for a limited time so since I'm up next now I'd rather just mix fuel just to get by and buy the tranny first. If you get my point. Then I'll save up for the tune (about 600-700) and retune. The fuel mixing will only be temporary so I can drive to work and back(about 25 miles). I can't take the bus or walk because I only work 12 hour shifts and no bus station operates that late. My normal schedule is 12pm-12am. I work in EMS btw...
Nah I understand where you're coming from. I normally just end up biting the bullet and living a little cheaper for a few weeks. When I upgrade I normally drop a lot of $$$ at a time so I know it's hard. I'd run octane booster personally and keep it out of boost as much as possible until you can tune. Like I said I've seen bad things happen from a crappy tune. I'd hate to see something someone's invested a lot into losing it.
As for biting the bullet and living a little cheaper, that's already what I'm doing. LOL I have 1k in my emergency savings but like I said, I don't consider this an emergency quite yet because the car is still running fine and should be fine according to some research I've done. Also, staying out of boost as much as possible is a must and I'm well aware of it. I'm just hoping everything will be fine until I can get it retuned. LOL
Simple, get retuned for 91, and stop ******* around before you come back hear crying you blew a ring or piston.
Take $300 of your "emergency money" because $1000 isn't enough to cover anything in a true emergency and can be replaced on the next paycheck.
Don't be stupid.
Don't be stupid.
Don't be stupid.
Don't be stupid.
Don't be stupid? First of all, if you can get me a hp tune for 300 then I'm down. Second of all, you never know how much money you're going to need in the event of a "true" emergency but 1k is a good place to start. It will be enough to supply me with food, water, and shelter for the time being so I don't think that's stupid at all. Last of all, I'm not crying or anything so let's get it straight please. If you have nothing nice to say then keep it to yourself.
I'm tired of people half assing cars then complaining. Do it right or don't do it at all is the only motto.
Nope, I clearly stated that it was zzp tuned and boost ramped so the hp tune would cost me quite a bit. But I do agree with your motto though. I'm trying to do it right but since I have the opportunity to ****** a 4.45 tranny now then I'd rather do that first and mix fuel for a bit til I can save up for the tune later. Don't know how many times I've repeated myself but it's quite typical for this site and I'm not only directing it at you. It seems like only 1 out of 10 members on here actually offer any help, the rest just loves to jump in and start bashing on you. Go CSS.NET!
Update: I just mixed about 2 1/2 gal of 104 with a little more than about 6 gal of 91 and the car seems to be taking it quite well. Floored it a few times with no lag or knock.
If that's the case then by all means, go for it
twilson380
Sep 14, 2015 10:52 AM
Macgyver2484
Sep 2, 2015 05:44 PM
