5 lug swap
Old Oct 31, 2013 | 04:11 PM
2010CobaltLTfan's Avatar
5 lug swap
Okay I no there are threads already made about this but really don't have the patients to go through all of them my cobalt lt is four lug and I need the cobalt 5x110 lug pattern I have disc brakes in the front and drums in the back i need to know how to swap them to the 5 lug plus I don't mind keeping the drums in the back and keeping disc in the front
Old Oct 31, 2013 | 07:27 PM
05g5's Avatar
dont you just buy 5 lug wheel bearings?
could be wrong, but i thought thats all you did. and our wheel bearings are easy to change... 30 min tops its out and in
Old Oct 31, 2013 | 07:29 PM
I heard it's something like that but I wanna know for sure
Old Oct 31, 2013 | 08:11 PM
BLKLS's Avatar
I did it, think I was one of the first.
Do you have abs? My car did not but I've heard that vehicles with abs will not work after and the light is gonna stay on.
Since your a 2010 I would think you won't need to change calipers and such. After 09 the lt had five lug so you should be able to just use front rotors, rear drums and 4 wheel bearings. Pretty simple, just double check part numbers about the calipers and brackets but I would think you would be ok. I did the swap and upgraded to LSJ front brakes so mine needed calipers also.
Old Nov 1, 2013 | 02:36 AM
Originally Posted by BLKLS
I did it, think I was one of the first. Do you have abs? My car did not but I've heard that vehicles with abs will not work after and the light is gonna stay on. Since your a 2010 I would think you won't need to change calipers and such. After 09 the lt had five lug so you should be able to just use front rotors, rear drums and 4 wheel bearings. Pretty simple, just double check part numbers about the calipers and brackets but I would think you would be ok. I did the swap and upgraded to LSJ front brakes so mine needed calipers also.
I must have been unlucky to get the 2010 4 lug lt but as far as I know my car does not have abs but if you could do me a favor if it's not to much to ask if you could list the parts I'm gonna need so I can start getting them if you don't mind I would appreciate it I'm not the most knowledgeable person when it comes to the swapping stuff
Old Nov 1, 2013 | 06:26 AM
BLKLS's Avatar
Sure. When I get gem later today I'll put one in here.
Old Nov 1, 2013 | 06:42 AM
mongorat427's Avatar
USE HHR parts
Old Nov 1, 2013 | 12:39 PM
Thank you
Old Nov 1, 2013 | 12:51 PM
andrewcarr1993's Avatar
I'll post my list I bought.
Part Number Part Type Price EA Core EA Quantity Total
2009 CHEVROLET COBALT 2.0L L4 Turbocharged
ACDELCO 18B597 Drum $ 28.79 $ 0.00 2 $ 57.58
RAYBESTOS 9982N Lug Nut $ 1.82 $ 0.00 20 $ 36.40
TIMKEN HA590086 Wheel Bearing & Hub Assembly $ 118.79 $ 0.00 2 $ 237.58
TIMKEN HA590088 Wheel Bearing & Hub Assembly $ 114.79 $ 0.00 2 $ 229.58
2009 CHEVROLET COBALT 2.2L L4
ACDELCO 17800B Brake Shoe $ 46.79 $ 0.00 1 $ 46.79
Discount $ -30.40
Shipping Priority Mail (1 to 5 business days), Ground $ 34.39
Order Total $ 611.92
After that you would need to decide if you want the Brembo brake swap, redrill your current rotors or LSJ brakes. I went with the Brembos from CED which is another $850
Make sure you get those same wheel Bearings, RockAuto is wrong the ones I bought wouldn't fit the SS/TC their SS/SC hubs which are the same as the base hubs.
Old Nov 1, 2013 | 01:26 PM
Are all these parts from rock auto
Old Nov 1, 2013 | 02:02 PM
sandman's Avatar
Discount $ -30.40
So you are still rockin drums in the rear?
Old Nov 1, 2013 | 02:06 PM
Yep.
https://www.dropbox.com/sc/oea0fb714vj0qe3/VT2Y_swkX9
Their not too visible though, and I plan on swapping the kit Powell made in the spring.
Their just the 5 lug drums painted black at the moment.
Yes I got all those parts from Rock Auto and the Brembo kit from CED.
Old Nov 1, 2013 | 02:08 PM
qwank's Avatar
I think I read if you want to change to disk, you need the whole rear axle off a disc car to do it right
Old Nov 1, 2013 | 02:12 PM
Powell makes brackets for the rear caliper swap. Im using a full rear axle swap though.
Old Nov 1, 2013 | 04:17 PM
That's why I mentioned Powell I'm going to use his brackets and the rest he fabed up so it's got a drum in the center for the e-brake and Brembo brakes on a disc around it.
Old Nov 1, 2013 | 04:22 PM
Damn thats a badass setup. Im using stock lsj.
Old Nov 1, 2013 | 09:41 PM
BLKLS's Avatar
That's about it really. Any parts store will have/can get what you need. You'll need new front calipers and caliper brakets, front rotors, and pads from which ever level of brakes you want. You have the option of the 5 lug LT brakes or the SS. Front wheels bearings, (as stated above don't use SS/TC bearings they have a different spline pattern for the axles) axle nuts, rear wheel bearings from a 5 lug LT, and drums from a 5 lug LT. You can reuse your rear shoes they are pretty much the same. I don't recommend cheaping out on the drums I went with the el-cheapo white box ones and one of them is out of balance, gives me a high speed braking vibration. And lug nuts.
I'd recommend using SS brakes not LT. Make sure you get the loaded calipers because they come with the brakets the unloaded may not.
I don't know how handy your are but if your gonna try to get a shop to do it, be prepared to pay. Expect to pay around 2 hours a wheel bearing. If you where closer I'd say I'd to it for you but VA is a few hours from me so. Good luck and let use know how it works out. Any questions hit me up.
Old Nov 1, 2013 | 11:07 PM
Took me two days because a stupid rotor wouldn't come off after an hour of hammering, sitting over night with penetrating spray did the trick with about 5 more minutes of hammering though.
Old Nov 1, 2013 | 11:21 PM
I want to thank all of y'all for helping me out i will be pm'ing both of y'all for more help I'm gonna probably need but I'll go ahead and get my buddy's ss rims and tires and when my brakes go bad that I have now I'll go ahead and do the swap then but thanks for all the info it's much appreciated
Old Nov 1, 2013 | 11:44 PM
BLKLS's Avatar
Yeah man.
Old Nov 2, 2013 | 02:53 AM
No, problem if someone had told me what was needed like in this thread it would have been a lot easier. I had a bit of help but not too much, I didn't know the difference in hubs when I first ordered but knew the Timken site listed the hubs I bought as 5 lug SS from 05-07 or something around there so I ordered them.
Feel free to message me, as you've done already I don't mind at all. (Edit that was someone else with the same question, oops)
Old Nov 2, 2013 | 11:21 AM
sandman's Avatar
A lot of us Base model guys are gonna like this one. Sub'd for future reference
Old Nov 3, 2013 | 10:57 AM
2.2balt's Avatar
I don't think this statement is correct. My understanding is that the Powell brackets are just caliper brackets that work with the drum-equipped rear axle. His conversion requires new handbrake cables (the rear disc models have different cables than drum cars), new lines on the axle, and a few other things. The handbrake is controlled by the OEM rear caliper, like on the disc-equipped cars.
I've been looking in to this over the last little while. Trying to plan a rear disc conversion and Brembos for next year, though my car already has the 5-bolt stuff (all 2007+ LT models with the 1SB pkg with the 5-spoke alloys have 5-lug) so that should be easier.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
ernnyyes
Oct 2, 2015 05:16 PM
ThoR294
Sep 28, 2015 05:31 PM
