Bad clutch?
Old Sep 15, 2014 | 07:49 PM
aebooth6's Avatar
Bad clutch?
When I WOT in first gear my car jerks a lot like it's losing power then regaining it. This has never happened before. Is this a possible bad clutch? I'm preparing for another race against my girlfriends charger rt and don't want this jerking to happen when I race him. What could possibly be wrong?
Old Sep 15, 2014 | 07:58 PM
09CobaltSS1's Avatar
When clutches slip they don't usually slip/catch/slip/catch like that in the middle of a pull. Generally speaking, your rpm's will raise, but the car will basically go nowhere for the most part. Plus first gear is the least likely of gears for a clutch to slip under power, however I suppose it could be possible given the right conditions.
Sounds like something else is likely going on.
Old Sep 15, 2014 | 08:12 PM
aebooth6's Avatar
Originally Posted by 09CobaltSS1
When clutches slip they don't usually slip/catch/slip/catch like that in the middle of a pull. Generally speaking, your rpm's will raise, but the car will basically go nowhere for the most part. Plus first gear is the least likely of gears for a clutch to slip under power, however I suppose it could be possible given the right conditions. Sounds like something else is likely going on.
So is there anything I should look for myself? Or just go get it checked out?
Old Sep 15, 2014 | 08:22 PM
What's done to the car?
Old Sep 15, 2014 | 09:19 PM
Squints's Avatar
Depends if he redlined it too long before the shift. After it "slipped" under WOT did it continue doing it on normal driving conditions?
Old Sep 15, 2014 | 09:55 PM
aebooth6's Avatar
Just a CAI, carted dp, and muffler delete
I didn't even get to redline. And normal driving when I shifted to second gear
Old Sep 15, 2014 | 10:03 PM
Squints's Avatar
It was slipping when you went to 2nd gear under normal driving?
Old Sep 15, 2014 | 10:08 PM
It's not clutch slip!! lol
Old Sep 15, 2014 | 10:18 PM
aebooth6's Avatar
No slipping
Then what could it be?lol
Old Sep 15, 2014 | 10:20 PM
Squints's Avatar
If it was slipping and then catching it would cause jerking my car did it to me when the clutch disc messed up. So that is why i'm using the term slipping. As far as his problem if it's just "jerking" then there are many problems it could be rather then just the clutch
Old Sep 15, 2014 | 10:21 PM
It could be many things based off the very limited info given. I strongly doubt that clutch issues are one of them though.
Old Sep 15, 2014 | 10:24 PM
Squints's Avatar
You and me both but just trying to mark things off the list. It could be anything. What we need is a run down of any mods to the car, a better description of the problem, what kind of car it is as far as model.
Old Sep 15, 2014 | 10:26 PM
Squints's Avatar
did you notice any strange smells coming from the engine? Because if it was your clutch you would smell something. Trust me it's a very noticeable smell too
Old Sep 15, 2014 | 10:32 PM
aebooth6's Avatar
It's a LNF. No smells but I know what smell your talking about.
Old Sep 15, 2014 | 10:34 PM
aebooth6's Avatar
It's like the car jerks back and fourth a lot until I shift. I don't know how else to explain it
Old Sep 15, 2014 | 10:43 PM
Squints's Avatar
LNF i'm out then. I don't have knowledge on the LNF's. However, it doesn't sound like your clutch.
Old Sep 15, 2014 | 10:45 PM
aebooth6's Avatar
Thanks for your help
Old Sep 15, 2014 | 11:06 PM
C Vanciu's Avatar
I've had that happen twice. First time it was my in tank fuel pump dying, it could also be the high pressure pump on the block. Second time it was the pcv line on the valve cover loose causing a vacuum leak
Old Sep 15, 2014 | 11:31 PM
aebooth6's Avatar
I haven't had vaccum leak. I'll get my fuel pump looked at
Old Sep 15, 2014 | 11:33 PM
Sl0wbaltSS's Avatar
Could be your car is bogging out. my brother had almost the same mods, except he had a catless dp and he got bogging after awhile.
Old Sep 15, 2014 | 11:34 PM
aebooth6's Avatar
So what does that exactly mean? How would I fix it?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
