Cobalt reliability
Old Apr 5, 2008 | 10:40 PM
bbbevans89's Avatar
Thumbs up Cobalt reliability
Just wondering if anyone has had any problems with there cobalt ss sc since they bought it because im going to get one and i dont want to buy a car that has many flaws.
Old Apr 5, 2008 | 10:43 PM
rockkrawler628's Avatar
yeap sure have
NamedGobalt's Avatar
i personally have had no problems with mine except my sunroof bezel fell off once.. But there are always factory defaults.. just look it over and check carfax
Old Apr 5, 2008 | 10:48 PM
bbbevans89's Avatar
Any Major Engine Problems?
Old Apr 6, 2008 | 12:14 AM
TheCaptain's Avatar
I have a small problem, kids with little di*ks keep trying to race me.
Other than that, i just had one headlight with an orange signal reflector, and one without. Problem resolved under warranty.
Old Apr 6, 2008 | 01:14 AM
carfax doesnt have alot of things...
you just gotta check the car over REALLY good
Old Apr 6, 2008 | 01:26 AM
Sharkey's Avatar
i had a crank position sensor changes under warrenty, and the previous owner had a wheel hub (bearing) changed as the abs sensor died. both freak failures, havent heard of many of either.
Old Apr 6, 2008 | 01:34 AM
hungryhip-ccp's Avatar
maybe your car was built on a friday
Old Apr 6, 2008 | 01:44 AM
Jn2's Avatar
Jn2
i have a ls, and so far, one rear tail bulb went out, the thermastat went bad, the ICM had to be replaced, and the cat got clogged
Old Apr 6, 2008 | 09:17 AM
Blue_Balt's Avatar
I have a LS as well and the only problem I've had is the power-steering motor acting up when I start it up for the 1st time and it's cold outside. I'm going to take it in this week to make sure nothing is truly wrong, as I don't need it to lock up on me while I'm on the road driving.
Old Apr 6, 2008 | 09:22 AM
They call me 'E''s Avatar
I'm pretty sure something is loose in my suspension, but I haven't got the time to go check it out yet.
Makes a rather disconcerting rattle when I hit a bump or something going slowly.
Old Apr 6, 2008 | 09:38 AM
stonny9's Avatar
Peeling door panel leather from being cut too short from the factory, Flex pipe blew out from a possible clogged cat, shift pattern fell off, very edge of trunk was not painted from factory, strips on top of car sealing seam of roog came loose and I have to bring it in because the hoses for the bypass are cracking and all the other hoses are fine.
All of this was replaced under warranty and did not make the car undriveable just really loud when the downpipe went. Also went into limp mode 1.5 years ago when I dropped it into second wich seems to have happened to a few people and and a crank position sensor failure code come up but it will go away in a few days if it doesnt happen again..
Old Apr 6, 2008 | 12:19 PM
YSUsteven's Avatar
You could just look in the Problems and Service section.
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
jcalvin1126
Sep 11, 2015 10:24 AM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
