Current Problems You Are Rolling With
Old Nov 19, 2013 | 11:35 PM
  #151
I have extra TPMS sensors I can sell you guys if interested.
Old Nov 19, 2013 | 11:37 PM
  #152
andrewcarr1993's Avatar
Those just need new valve stems then, those are like $4 a piece when they put on the tires.
Old Nov 20, 2013 | 01:51 AM
  #153
dieGone's Avatar
Originally Posted by Pinky Demon
Fuel filter is separate from fuel pump. It's an inline filter under the rear of the vehicle. Search for a replacement guide online. You may or may not need special tools, I can't remember at the moment. When you clean the MAF, do not actually touch the MAF grid. You'll have to take it out of the intake tract. Just spray both sides down with the cleaner and let it sit and dry. The TB you will want a large screwdriver to help prop open. The car may run rough directly after with some smoke so don't worry. As for the battery, no it won't pop any fuses because you are essentially completing the main circuit on the car with no power applied.
Thanks Man U were great help! Tomorrow's my day off so I'll do all this. Thanks for the tips I would've been scared if I saw smoke after the throttle haha
Old Nov 20, 2013 | 03:14 AM
  #154
taintedred07's Avatar
I need a giant tube of jb weld to fill the hole in my block does that count?
Old Nov 20, 2013 | 03:37 AM
  #155
sternerG85SC's Avatar
Shitty torn OTTP mounts that ive had istalled for only 6months, and some worn control arm bushings... just waiting for black Friday!!
Old Nov 20, 2013 | 10:19 PM
  #156
keiserX13's Avatar
what spare cobalt part dont you have?
Old Nov 21, 2013 | 02:34 AM
  #157
dieGone's Avatar
I just cleaned my throttle body and now my car idles at 1500 what to do!! I hate riding the clutch like this. I'm already trying to force down the revs by putting it in 1st and braking and it does work sometimes it brings it back to 800 (regular rpms) but once you turn it off it goes back to 1500....
Anyone has any experience with this topic?
Old Nov 21, 2013 | 02:43 AM
  #158
SS/TC seats he probably doesn't have, and if he does have those I'll buy them so he doesn't have them.
Old Nov 21, 2013 | 08:19 AM
  #159
blueLNFftw's Avatar
email josh.
Old Nov 21, 2013 | 08:33 AM
  #160
trans issues...
sometimes hard to get into 1st and reverse
often smelling burning clutch/electronics smell
slight thumping noise kind of like warped brakes but coming from the clutch area...
horrible noise when flooring it
tob?
Old Nov 21, 2013 | 06:48 PM
  #161
Probably gonna be one of the hardest things for you to find.
Old Nov 21, 2013 | 07:01 PM
  #162
Disposable-Hero's Avatar
Full set of TC seats go for a grand on ebay. nice set on there now with the grey suede
Old Nov 21, 2013 | 07:37 PM
  #163
Pinky Demon's Avatar
Where to start lol.
Old Nov 21, 2013 | 11:35 PM
  #164
Kolt's Avatar
hmmm so much lol. running one hid and one halogen bulb. carpet is out b i spilled lucas in the back floor, been out for 2 months, took a year before i finally took it out in the first place. now my foot rest is worn (its only foam underneath). trunk leaks around the 3rd light and spoiler. so i took everything out to seal/custom build a system setup... rotors are warped. have ebc red and slotted/dimped rotors ready. both front shocks are toast, and bump stop seperated(like all cobalts) from the shock bearing. passenger sunshade mirror is falling off. errr.... still have a dent that needs fixing on running board were i ran over a metal beam on the highway. (took paint down to the primer so no rust for now). still need to do a timing chain, tensioner, guides and sprockets before its too late.
Old Nov 21, 2013 | 11:37 PM
  #165
Define "rolling" with lol
https://www.cobaltss.net/forums/2-0l...thread-304457/
Old Nov 22, 2013 | 12:02 AM
  #166
Jeez. How many miles?
Old Nov 22, 2013 | 12:22 AM
  #167
I should be getting my problems fixed this Saturday, yay Powell parts.
Old Dec 21, 2013 | 10:42 PM
  #168
Bika's Avatar
Fail Less.
I'm digging up this thread again...
More problems as shown in pic
P0030 Heated o2 sensor bank 1 sensor 1.
P0102 MAF sensor circuit low frequency
P0443 EVAP purge solenoid valve 1 control ckt
P0833 Clutch pedal switch B circuit
FML
I know my manifold 02 sensor is done and can get one of those at work.
The MAF sensor I'm not sure yet if its just dirty, or if the sensor is done. Its getting Zero reading.
EVAP I have been throwing various codes for years. smoked and pressure tested the whole system and found no leaks, even replaced the gas cap, purge solenoids, and valves. I just tune out the codes. Not worried about this one either
Clutch Pedal switch? WTF does this effect?
Old Dec 22, 2013 | 03:16 PM
  #169
Bika's Avatar
Fail Less.
Also cruise control isn't working, likely due to the clutch pedal switch.
Old Dec 22, 2013 | 03:40 PM
  #170
tuned08ss's Avatar
P013e can I clear this with an interceptor?
Old Dec 22, 2013 | 11:05 PM
  #171
TylerLatigo's Avatar
i have a dent in my intercooler that is giving me 0 boost can anyone diagnose the issue for me? takin it to a shop in the am just wanna heads up ya know.
Old Dec 22, 2013 | 11:13 PM
  #172
footballplaya3k's Avatar
...it's leaking?
  #173
Bika's Avatar
Fail Less.
If the interceptor can read it, it can clear it. However if the O2 sensor problem isn't remedied the code will just be right back.
Description
O2 Sensor Delayed Response - Rich to Lean
Bank 1 Sensor 2
The dent in the IC is either so restrictive the pcm is cutting boost or there is a hole in the IC causing a boost leak.
Old Dec 23, 2013 | 08:18 AM
  #174
tuned08ss's Avatar
Description
Bank 1 Sensor 2
P013e is to me a hard fix. I have a zzp dp
Old Dec 23, 2013 | 03:08 PM
  #175
there is no coolant leak or anything and when i accelerate you can hear the turbo wanting to spool but something is stopping it from getting boost it stays at a solid 0 and when i come to a complete stop it revs and on the boost meter the vac needle revs between 20-25.
