Current Problems You Are Rolling With
Old Nov 12, 2013 | 12:03 PM
  #101
05g5's Avatar
I could have bitched for days with all the small problems i had. Right now, seeing as this car is my DD and im on week #3 tracking down a problem, all the other stuff doesnt seem too bad.
but, the suspension clunks,
the 2 month old break pads that grind
minor cosmetic work needing done
rear defog doesnt work
etc
STILL have a special place in my heart
Old Nov 12, 2013 | 12:13 PM
  #102
newguy80's Avatar
What has been going on with your ride that you have been either planning to fix, or have just been putting plans of fixing it on the backburner? I know we all have some issues, some we may not even know what they are.
Hopefully we can help other members as well as vent in this thread
As for me...
Front struts are shot, one is leaking (new ones on order!)
Clicking either from axle or control arm bushing (gonna replace bushing when i do the struts)
Small hissy exhaust leak somewhere... have header gasket but way too lazy to replace
Front brakes are about shot... just riding these suckers out
I fear my passenger window is rolling up so slow its gonna quit on me one day soon
I.C. pump sometimes works and sometimes doesnt, plan to replace with a bigger pump one day
have same issue with passenger side window... too lazy to fix though... had a bad whistle coming from what sounded like the engine when i WOT, finally took it in after trying everything. in the end it was a clogged cat fixed under warranty. now i gotta figure out what I want to do next....
Old Nov 12, 2013 | 12:21 PM
  #103
Avalanche687's Avatar
Rattling.....rattling everywhere
Old Nov 12, 2013 | 12:23 PM
  #104
newguy80's Avatar
rattle rattle rattle
Old Nov 12, 2013 | 12:25 PM
  #105
InfraRedline's Avatar
Got the daily running last week. Need some love. The rear struts are some janky aftermarket ones that let me bounce the rear end like a basketball. The mounts are the vibes are a bit much,misc interior pieces have broken tabs that don't allow them to fasten correctly. There plenty of small things that need addressing but it runs great
Old Nov 12, 2013 | 12:50 PM
  #106
owlwyn's Avatar
hmm...
well my bower motor ticks when its on.
my trans feels odd when I shift at times (feels clunky)
there's a creaking in my front end when I go over a bump in the morning when its cold, i have a feeling its my bushing.
I need rear tires because racecar
i need front rotors, they shake when warm.
my front speakers still dont work, bought the car a year and a half ago with this problem, but I diesnt bother me. since my car can't ding at my when I dont wear my seat belt, and because dubstep and subs. haha.
and I need to paint my cheap exhaust I got from car quest to replace my fart can. its discoloring already, 2-3months old.
Posted from Cobaltss.net App for Android
Old Nov 12, 2013 | 01:01 PM
  #107
Wired's Avatar
Originally Posted by owlwyn
hmm...
My 07 SS/NA did that same thing from the day I bought it to the day I sold it. 75000 miles in all.
Also the blower motor can be replaced. Not too hard. Check 1aauto.com. They have a nice tutorial on it on the page for the replacement motor.
Old Nov 12, 2013 | 01:07 PM
  #108
Kyle09TC's Avatar
My car is only at 60000km
Im lowered so everything makes noises
sunroof really noisy- have to realign it or something
need to get a new revision from trifecta so i can put my other ECU back in
Lastly, Need new tires and an alignment
Old Nov 12, 2013 | 01:18 PM
  #109
owlwyn's Avatar
the blower motor isn't bothering me, yet.
but the creaking is driving me nuts. >.<
Old Nov 12, 2013 | 01:30 PM
  #110
LotusRenaultF1's Avatar
Camshaft actuator solenoids are shot. Easy fix
Old Nov 12, 2013 | 02:15 PM
  #111
owlwyn's Avatar
been there. fixed both already. last time it was my intake side and it sounded like it had a lope to it. it even rocked. and that was this spring down at cruise week. I got some funny looks. haha
Old Nov 13, 2013 | 09:12 AM
  #112
craig825's Avatar
Filled up at sheets the other day and now the engine light keeps coming on then going off with a "bank 1 too lean" code. Guessing moisture in the fuel. Going to put some heet in the tank before next fill up.
Pulls to the right a little on the highway.
Mystery rattle coming from the rear. Only happens some days.
Passenger door "lock, unlock" button doesn't work.
Passenger window becoming slow to roll back up.
Sun roof button ring falls off when i hit a bump.
Heater/AC fan makes a HELL of a noise if it isn't off or on full blast. Only makes me want to shoot my dashboard A LOT.
"Low coolant" light keeps coming on even though every time I check, the reservoir is full.
Old Nov 13, 2013 | 09:35 AM
  #113
nobody2u's Avatar
Right now I busted an endlink trying to change my front springs again. Have to put my moog ones on this weekend.
Old Nov 13, 2013 | 09:46 AM
  #114
blueLNFftw's Avatar
how???
Old Nov 13, 2013 | 09:52 AM
  #115
nobody2u's Avatar
how???
I think the top bolt was seized on or something, when I went to remove it, it wouldn't come off properly, I think I busted the ball joint in it or something. The sway bar rattles and clunks over bumps now.
Old Nov 13, 2013 | 10:26 AM
  #116
Kyle09TC's Avatar
Probably wasn't seized, they are just a b***h to get off, the back just spins so you have to use an impact and go on and off until it breaks free. cutting them off is an easier solution sometimes
Old Nov 13, 2013 | 06:27 PM
  #117
Pinky Demon's Avatar
+1. Don't waste your time, just cut that **** off.
Old Nov 13, 2013 | 06:52 PM
  #118
nobody2u's Avatar
Yeah that's what we ending up doing last time... Just sucks having to buy new end links every time you change the springs.
Old Nov 14, 2013 | 09:52 AM
  #119
**** those stock end links.
Old Nov 14, 2013 | 10:28 AM
  #120
574's Avatar
574
I've been lucky lol. I've had mine Un bolted probably ten times since I've had the car
Old Nov 14, 2013 | 10:39 AM
  #121
nobody2u's Avatar
Hopefully I'll have the same luck with the Moog endlinks.
Old Nov 14, 2013 | 07:59 PM
  #122
I haven't had my Moogs off yet, but they shouldn't give you problems like the stockers.
Old Nov 14, 2013 | 08:08 PM
  #123
my moog stuff is working great but something else is clunking in the front end now...
Old Nov 14, 2013 | 10:20 PM
  #124
Nah. Vehicle operating as designed lol.
If something isn't clunking in the front end, you aren't driving a Cobalt.
Old Nov 14, 2013 | 10:58 PM
  #125
nobody2u's Avatar
Mine has only ever given me problems because I fucked with it, not the car's fault.
