Current Problems You Are Rolling With
exhaust leak from one of my vbands. i always forget about it till i go and start it. by then it is too late to tighten them.
is it only 1 click when you start going forward or backwards? if so i had that. replaced my axles and it hasnt done it since.
What has been going on with your ride that you have been either planning to fix, or have just been putting plans of fixing it on the backburner? I know we all have some issues, some we may not even know what they are.
Hopefully we can help other members as well as vent in this thread
As for me...
Front struts are shot, one is leaking (new ones on order!)
Clicking either from axle or control arm bushing (gonna replace bushing when i do the struts)
Small hissy exhaust leak somewhere... have header gasket but way too lazy to replace
Front brakes are about shot... just riding these suckers out
I fear my passenger window is rolling up so slow its gonna quit on me one day soon
I.C. pump sometimes works and sometimes doesnt, plan to replace with a bigger pump one day
As for me...
Yep, but I don't think either are worth putting the money into at the moment so they get only the essential mechanical stuff repaired. Work on the small crap a little at a time when I get the spare $.
-Also have a clicking when going into Reverse / once in a while moving in first
-Riding on stock clutch that cant handle WOT, but have everything for clutch job
-have a shimmy at about 65 miles an hour that happens on cold days. I thought it was a tire (actually leaning more to the tire as the shimmy will happen on braking but on warm / hot days its not there any more). I have the R1 Concept brake rotors / brakes, but dont think its a rotor as it doesnt shimmy when braking every time.
Thats just the SS,
For my truck,
-Rotors have minor warpage, gonna put them on the lathe soon
-Have to fix the driver side door sensor as the lights dont turn off all the time when opening the door
For my Mountain bike
-front innertube is flat, need to buy a special innertube as the stem cant be standard length, I have deep rims for rough terrain so I need special innertubes.
Now you guys know only a fraction of my bullshit ... hahah
Thats just the SS,
For my truck,
A super low mileage 07' might be worth $12k, but I would be sure it is mint before even thinking about paying that.
i have a issue with my T/C it is constantly on. It work once in a blue moon but have been able to figure where to start, and im not a parts changing kind of person i rather fix the problem the first time around. Verses changing this and that till it corrects the problem some mentioned a sensor on it but have not been able to locate it there in again not sure what im looking for either new to these T/C systems. but would like to fix it due to i fear the damage it might cause to my car with the hard shifting ect..
Need shocks and struts, chase down a possible disconnect in my turn signal lights. They work but if the lights are off like daytime, all four will flash like hazards but the opposite side will flash dim.
Drivers rear caliper is leaking
Passenger front strut leaking
Passenger window motor appears weak
Slight rattle from under car under small load (exhaust shield is the probably culprit)
Drivers projector turned on its own
That's about it for now.
