For discussion of all things Powell!!
Old Mar 13, 2016 | 02:48 PM
  #1726
Powell Race Parts's Avatar
Originally Posted by rrob5382
Don't suppose you make one for a sedan? Under car rails should at least still work on a sedan though right?
yes I am working on a roll over hoop for redlines and maybe sedans that will tie into the UCR
Old Mar 13, 2016 | 03:00 PM
  #1727
rrob5382's Avatar
Okay cool, I'll have to send you an email one of these days when I get back to buying parts again haha
Old Mar 24, 2016 | 09:27 AM
  #1728
Flarfignewton's Avatar
I installed a set of Powell stage 1 mounts yesterday and I don't know why I waited so long to get them. I followed the instructions provided and only took about an hour or so. I noticed an increase in traction and the whole car just felt more solid without the motor shifting around. The best part? No additional vibrations! Thank you Mr. Powell for creating such a high quality product, will definitely be ordering more in the future.
Old Apr 7, 2016 | 02:49 PM
  #1729
jdbaugh1's Avatar
I have Powell UCR, Front control arms with spherical T-CABS, YYZ springs, Hardcore rear bars, tow hook, F23 engine mount, powergrid endlinks that you sell. If only I could get a trap door oil pan I would be set!
Old Apr 8, 2016 | 09:32 AM
  #1730
yellowsupercharged06's Avatar
i have a trap door oil pan what you willing to pay lmao
Old Apr 11, 2016 | 09:36 AM
  #1731
jdbaugh1's Avatar
Will it go on an L61 2.2L?
Old Apr 11, 2016 | 10:04 AM
  #1732
blueLNFftw's Avatar
What is the LNF PCV solution running price wise right now?
Old Apr 11, 2016 | 10:25 AM
  #1733
63 Nova SS's Avatar
He has a new slick setup that Adrian is using that comes with a new intake. I think that's the way to go but it's probably not cheap.
Old Apr 11, 2016 | 10:44 AM
  #1734
He has a new slick setup that Adrian is using that comes with a new intake manifold. I think that's the way to go but it's probably not cheap.
Def don't need the intake manifold, but it works a lot better with it. Shot Powell an email for the fastest response, he doesnt seem to be on the forum much anymore.
Old Apr 11, 2016 | 11:46 AM
  #1735
63 Nova SS's Avatar
They have been really busy I know. He frequents Adrian's Facebook road racing page I know but even then it's hit and miss.
Old Apr 11, 2016 | 02:50 PM
  #1736
Viperoni's Avatar
I needs to get me one of them
Old Apr 11, 2016 | 03:06 PM
  #1737
blueLNFftw's Avatar
I wouldn't want thAt version.
Old Apr 11, 2016 | 04:37 PM
  #1738
heeter_33's Avatar
Version 2 is around $395 I believe.
Old Apr 12, 2016 | 11:47 AM
  #1739
LSJ is a different pan wont work on your car. The good news is, after your long wait, we have changed the manufacturing process to avoid defects and will ship you a brand new trap door pan next week that fits your engine
Old Apr 12, 2016 | 01:15 PM
  #1740
jdbaugh1's Avatar
Awesome! Will my oil capacity change or is do you start with the same stock pan?
Old Apr 12, 2016 | 03:57 PM
  #1741
same capacity as your OEM pan
Old Apr 15, 2016 | 09:03 PM
  #1742
I may not have mentioned that we have changed the way we make trap door pans, so while there is machining done we don't weld on the pan case. The material hates being welded....
some new parts we are producing:
a clutch master cylinder repair plate, works great on Redlines, the Cobalt is a little more involved as the clutch pedal has an extra support that needs to be removed
About 30 dollars shipped
For Ion Redlines, a new strut mount assembly that allows use of adjustable koni shocks and to adjust them in the car. Redlines are weird. Cobalts have it easy
Not cheap, the kit comprises new mounts modified parts with new bearings. Contact Gloria@powellraceparts.com as she can provide a break down of parts if you already have new mounts.
A version 3 for our successful PCV upgrade that eliminates the in manifold PCV valve and runs the valve inside the separator itself. We didn't think we needed to go this far, but as power demands get higher this is a nice option to do. We have run a v.3 style vent path for two years with success. The v.3 is available as a parts kit for folks with v.2 already, if you don't want to buy a new manifold. Same deal, contact Gloria@powellraceparts.com with your specific needs. Note that the different engine configurations have different PCV - kappa, LNF cobalt, LDK Cobalt, big turbo cobalts, LSJ and Lsj t and Redlines.
we have lots of new manifolds, thanks to ZZP for the source.
powdercoating is an option
Old Apr 15, 2016 | 09:06 PM
  #1743
Oh and I got tired of looking for moulded hoses to make a nice dual pass interface, so we offer this nifty machined manifold to go with a dual pass end plate
Gloria@powellraceparts.com. Not cheap this one. The dual pass end plates are not expensive however.
Old Apr 15, 2016 | 09:13 PM
  #1744
For the road racers we copied idea from the plastic Porsche GT3 flca brake scoops, and made them for Delta. Made out of alloy and a simple bolt on, they really help with brake cooling in extreme conditions, without any of the spindle ducts and expensive hose ducting. Running brake cooling hoses on a Cobalt is very difficult due to the rear steer rack, the front caliper mount and no easy routing for the hoses from the fog light or radiator grille area.
This is easy and not a lot of money.
Colordude has a picture of them on his car.
Old Apr 16, 2016 | 08:17 AM
  #1745
calo247's Avatar
more parts i want haha, thanks for the continued innovation John
any changes to the lsj version of the pcv?
Old Apr 16, 2016 | 10:17 AM
  #1746
colodude18's Avatar
So much win in this thread!
Old Apr 16, 2016 | 10:25 AM
  #1747
I really can't wait till this shitty snow leaves and we can see how much better your times will be with the brake ducts and oil cooler
Old Apr 16, 2016 | 03:17 PM
  #1748
The LSJ SC version will plug manifold but draw out of the rocker cover. That will take a little finesse.
At the moment I am working on understanding if there is potential for condensation build up as the blow by gasses cool off too much. I am not sure. Has not happened on the kappa test car over two years. Ryan has not said anything.
Only one LNF is a potential concern. I can't test lsj stuff on my car as it has not any headlights or tail lights currently. Lol
Old Apr 16, 2016 | 06:44 PM
  #1749
yeah can you make parts now for 5.3 colorados? that would be great thanks
Old Apr 16, 2016 | 07:58 PM
  #1750
colodude18's Avatar
You and me both!
Working on your headlights this weekend John! You need to remind Gloria again to send me those tails.
