Does anybody know this Cobalt SS?
Old Dec 12, 2011 | 08:12 PM
  #51
turbocharged717's Avatar
Originally Posted by Gobolt210
haha i felt a couple mean looks at a meet couple weeks ago and let them get to me so i No-Lift-Shifted 1st gear, backfired and roasted the tires through out 2nd gear and outta the parking lot like a BAWS.. never see the ricers at the meet do that :P
Nice! How can i tell about the g85?
Old Dec 12, 2011 | 08:22 PM
  #52
Gobolt210's Avatar
theres a couple ways to find out, the easiest for me was in the trunk where the spare tire is on a small metal panel theres a list of the options your balt has and G85 is the LSD.
Old Dec 12, 2011 | 08:27 PM
  #53
Good stuff. Thanks for the info man.
Old Dec 12, 2011 | 10:10 PM
  #54
SSRich's Avatar
yea 20psi by 2nd gear for sure possibly spiking 21 or 22. i do dig runs but never really last long in 1st gear but im almost certain our cars stock are not suppose to be buildin much boost outta 1st gear (unless tuned) i think i get mine up to maybe 4-5 psi in a 1st gear romp but normally the needle in the boost guage is jus flickin around the vacuum side with your throttle input. ( as if you were jus creepin around a parking lot )
i believe it was first gear lol alot of traffic little gauge and not that great at stick shift and the salesman with me it might have been 2nd gear at 6 1/2 rpm 15psi
Old Dec 13, 2011 | 12:01 AM
  #55
Gobolt210's Avatar
You got a good testdrive in. I did mine like 3 times.
Old Dec 13, 2011 | 12:34 AM
  #56
insylem's Avatar
The eaiest way for me was to read the seat that said "Recaro" on it, as the Recar seats come with the LSD in the G85 package.
Old Dec 13, 2011 | 12:35 AM
  #57
insylem's Avatar
Old Dec 13, 2011 | 01:15 AM
  #58
EmperorJJ1's Avatar
that is the easiest way but with seat swaps that doesnt mean it has it
Old Dec 13, 2011 | 01:31 AM
  #59
insylem's Avatar
True but then you must also consider
with Tranny swaps, means could say G85 with out an LSD then....
Old Dec 13, 2011 | 02:36 AM
  #60
EmperorJJ1's Avatar
true true but id guess that seat swaps are more common then tranny swaps
Old Dec 13, 2011 | 02:58 AM
  #61
stormtrooperxl's Avatar
Don't think the turbo G85 came with recaro's might be wrong though
Old Dec 13, 2011 | 03:29 AM
  #62
FasterIsBetter's Avatar
Theyre the same design as the recaros, just with suede and they don't say recaro on the seats.
Old Dec 13, 2011 | 03:52 AM
  #63
EmperorJJ1's Avatar
but all tcs came with those seats not just g85
Old Dec 13, 2011 | 11:10 AM
  #64
soundjunky's Avatar
Nice, i think that the product # How much does yours boost? it says 20psi but i get 21-22psi here in Tx. Also the are some pretty Bosch sensors u can find 1 above the exhaust manifold (i think it is) and 1 down below it.
actually;
the GMS1 does use Bosch sensors, but they are replacement MAP sensors;
MAP = Manifold Air Pressure
they are on the intake, and hot side charge pipes;
the intake one would befront and center ~ just open the hood, the sensor with the horizontal plug right infront of you would either be one of these two;
stock upper and lower MAP ~ the one on the left is the intake manifold one
GMS1 MAP (both the same)
Stock the cars are rated for 15lbs - GMS1 they are rated for 21lbs ~ but depending on the conditions, you could see slightly higher boost than they're rated for...
nuff said?
I believe there is a TAG ontop the transmission - infront of your oil cooler that shows the RPO: G85 ~ otherwise, it's easiest to look on your car's RPO sticker - lift your trunk mat ~ it's a large silver sticker on the trunk floor roughly inforont of the sub.
To the best of my knowledge for unmodified cars this pertains to 2005 & 2006 SS/SC Cobalts exclusively ~ but I've seen Recaros swapped into car too...
I have come to understand that the 2005-2006 Cobalt SS/SC combined the limited slip and recaro option, while the 2007 model year saw the two items separated...
for example, a buddy has a 2007 non-Recaro SS/SC w/G85
Recaros were discontinued for he Cobalt after model year 2007.
Nope.
They are somewhat similar ~ but are vastly different...
Recaro
SS/TC
Seat foams are different, head rests are different, lumbar is different, material used is different...
2005-2007 Recaro equipped cars had rear seats with perforated seat inserts ~ with bright stitching along the endges ~ the 2008-2010 SS/TC used back seats which mimicked the front seats...
Old Dec 13, 2011 | 11:13 AM
  #65
nizzle's Avatar
those stripes are OOOOOOGLY!!
Superslowbaltt
Sep 22, 2015 10:24 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
