does your oil go black fast?
Old Apr 25, 2007 | 04:31 AM
senior_brown's Avatar
i swear, last time i had an oil change my oil was black in 2-3 weeks,
i've used fram and delco filters, mobil1 and both combos do the same thing,
i change it every 7500km, OLM reads just below 30% everytime
anyone get this too?
Old Apr 25, 2007 | 07:27 AM
Fade.To.Black's Avatar
thats messed up.. i change mine every 5000kms or 2-3months.. and its still gold when they change it (OLM reads about 55% after 5000kms..)
you should probably get that checked.. 2-3 weeks is WAY too soon for oil to blacken like that
oh and dont use Fram filters.. they are apparently garbage
Last edited by Fade.To.Black; Apr 25, 2007 at 07:27 AM. Reason: Automerged Doublepost
Old Apr 25, 2007 | 07:35 AM
07cobaltowner's Avatar
lol, i dont worry about what my oil looks like. thats why i have the dealership change it and have a 5year 100,000 mile warranty
Old Apr 25, 2007 | 07:37 AM
last time i went for an oil change and a semi-annual check up at my dealership.. it ended up costing me 263$.. screw that
Old Apr 25, 2007 | 10:58 AM
Halfcent's Avatar
I'm old school
Oil turns black from blow-by. Burnt gas from the cylinders during combustion leaking past the rings and mixing with the oil is what causes the color change. Do a compression check or differential pressure check to see if you have a bad ring.
Old Apr 25, 2007 | 11:53 AM
BLKSS's Avatar
yea i noticed that too, my oil gets black REAL fast, I hope my balt is ok.
Old Apr 25, 2007 | 11:56 AM
kissmySS's Avatar
Would there be a slight performance change with this? and if so would it be noticable, any drivability issues?
Old Apr 25, 2007 | 01:02 PM
id like to know this as well, my car drives the same all the time, and its stil got great ***** to it, i have not noticed a loss in performance at all
Old Apr 25, 2007 | 02:37 PM
NapaGuy's Avatar
a better filter equals higher capacity, improved flow rate both in single and multi pass with better filter media and the like. this all allows for a cleaner oil.
Old Apr 25, 2007 | 02:52 PM
88cobaltSS's Avatar
You also have to keep in mind that if your oil is black then it is absorbing any imporities/carbon build up that will create engine sludge so there for it is doing its job, and those particles picked up by the oil leave when you change the oil.
Old May 25, 2007 | 01:27 AM
eurochevy's Avatar
i stopped reading after 7500km's........
Old May 25, 2007 | 01:36 AM
liolixli's Avatar
30%... I let mine get down that low right now and I'm scared to drive it too much. Not that the percent matters as much as actual miles and driving style. Still I think the scale should be adjusted by 25-35%. I changed mine around 45-60% the last times. It was just about right.
Old May 25, 2007 | 06:12 AM
06blackSC's Avatar
synthetic oil also darkens faster than a conventional oil. the synthetic has special additive packages that help trap and remove sludge and carbon that most conventional oils cant. i'm sure you'll be fine.
Old May 25, 2007 | 06:45 AM
css9450's Avatar
Mine seems like it'll never turn black. I've never had a car before this one where the oil was still golden when I drained it out.
I should save my old oil and sell it to the neighbor for use in his minivan.
Old May 25, 2007 | 07:27 AM
D4u2s0t's Avatar
well, maybe you should keep reading... because 7500 km is really not a bad interval with synthetic.
Old May 27, 2007 | 08:49 PM
Saint_Berzerker's Avatar
I'm at over 8000 miles with Royal Purple Synth and the stuff is still dark yellow.
Old May 28, 2007 | 12:22 AM
SSdan's Avatar
I was told back when I was in school for Engine Rebuilding that black oil is a result from removing carbon deposit buildups.
Old May 28, 2007 | 01:21 AM
Halfcent's Avatar
I'm old school
No. Oil turns black from burnt gas.
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
