fuel pump have a kill switch?
i was working on my car, i had to remove the fuel pump relay so i could get rid of the fuel pressure, now i turn on the key and i dont hear the pump, so.... my question is do we have a kill switch for the pump and where is it?
bump. anyone?
bump. anyone?
Last edited by Mnatvyc1223; Sep 16, 2007 at 08:22 PM. Reason: Automerged Doublepost
Chevy's arent like fords, all fords actually have a fuel pump kill switch that gets activated on impacts to stop the fuel to the engine in case the crash creates a fire hazard. I've never seen one on any other car, not crash activated like fords anyways, but i could be wrong. ( i'm a bodyman)
Try unpluging the battery for 5 mins plugging it back in, to reset the electrical components. if that doesnt work check your fuses, replace any blown ones. If that doesnt work take apart what you just put back togheter and make sure you didnt forget to plug anything in, like the fuel pump for example. ;-) I usually find out what i did wrong that way. Good luck. ;-)
i pulled the right fuse, i put the key in the ignition and i dont hear the pump pressiruze, i'm not getting any fuel at the rail...
Well if there was a kill switch, wouldn't it be controlled by the computer?
Like, the air bag sensor is triggered in a crash and it disables the fuel and explodes the air bags? It says in the manual that it unlocks the doors and opens the windows and turns on interior lights in case of a crash, so maybe the fuel pump shutdown is part of that?
If that's the case, you'd either have to program the fuel pump to stay closed or disconnect the wiring.
If you pulled the fuse or relay , you may need to use the "key" on the lid of the fuse cover to make sure the fuse/relay gets installed exactly in the right pins. You CAN install the fuse in "dead" spots in the fuse panel. That or you blew the fuse somehow...
Wop
Wop
thankfully we had another car to verify with.
Mnatvyc1223 pm your address and I'll swing by.
well u were right, i'm a dummy +1 for u
Sl0wbaltSS
Nov 21, 2018 11:11 PM
roth
Sep 26, 2015 12:16 PM
