HELP! weird issue with not starting...
Old Aug 21, 2011 | 11:10 PM
mrader88's Avatar
Hey guys, i have a weird issue with my 06 cobalt ss/sc. as of lately when i get gas the car wont start afterwards unless i manually give it gas. and this only happens when i get gas, doesn't matter if i put in 10 bucks or fill it up, if i put any gas in it at all it wont start until i push the gas pedal down and i have to hold it down a little so that it idles and doesn't die for about 30 seconds to a minute, then its fine. i don't know if its related or not but the computer also tells me to check the gas cap on occasion (once or twice a month) and of course its on and fine, i even replaced the gas cap 2 times thinking maybe i got one that is not sealing correctly or something but no help. I have asked local mechanics and even the dealer and they cannot explain why the car wont start after getting gas, any ideas guys? thanks for the help!
Marshall
Old Aug 22, 2011 | 02:16 PM
Chevrolet Cust Svc's Avatar
Hi Marshall,
Would you mind sending me a PM with your VIN? I’d like to investigate this a bit. Also, did the dealer attempt a fix at all or did you just ask for their opinion?
Thanks,
Laura
Chevrolet Customer Service
Old Aug 22, 2011 | 04:23 PM
DaBuzzard's Avatar
Sounds like a faulty purge solenoid to me.......
Search "purge solenoid" and you should get some dierction to fixing it
nvm, everything you need right in this section https://www.cobaltss.net/forums/gene...lenoid-258954/
Old Aug 22, 2011 | 10:44 PM
mrader88's Avatar
laura,
i asked the dealer what they thought it would be and they said they had no idea, its not under warranty and i wasnt going to pay them to look at it if they didnt have a clue before hand
buzzard
thanks ill take a look at it now!
Old Aug 23, 2011 | 06:24 AM
mrader88's Avatar
I found this when searching online about the purge solenoid,
The evap purge solenoid is sticking in the open position. This will cause the hard stars and the gas cap light, the computer uses the solenoids to hold fuel vapors in the tank and in the charcoal canister when the solenoid is stuck open the fuel vapors are allowed to be sucked into the engine this floods the engine and causes a hard start. The computer also sees this as a vapor leak on the fuel tank and will turn on the gas cap light and the check engine light.
I think this will fix my issue thank you guys! I'll post a reply to verify!
Old Aug 23, 2011 | 02:23 PM
DaBuzzard's Avatar
Hope it is the answer, $50 bones and an hour of your time or three trips to the dealer, $$$$$$, and "We haven't been able to duplicate the problem"
I know which one I would rather deal with
Old Aug 24, 2011 | 12:52 AM
josh714's Avatar
I have the same exact issue with my 06 SC! I did however find out that my gas tank is leaking so I'm thinking that the lack of pressure in my tank might be the issue or the solenoid..
Old Aug 24, 2011 | 01:07 AM
jonathan923's Avatar
Originally Posted by mrader88
laura,
buzzard
theres no surprise in that
i hope you get it fixed man
Old Aug 24, 2011 | 05:15 AM
mrader88's Avatar
It may be a little of both! I ordered the part from advance auto parts local here for 29.00 I should get it today I'll be sure to post if it fixed it or not!
Old Aug 24, 2011 | 06:49 PM
mrader88's Avatar
its all fixed, the purge solenoid fixed it, cost me 30.00 and took all of five minutes to change, starts and runs like a champ! thanks for the help guys
Old Aug 25, 2011 | 07:07 PM
DaBuzzard's Avatar
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
