installing springs, URGENT! HELP!
Old 07-13-2008, 10:58 AM
wbrevels's Avatar
STEP: "-Take out the 2 bolts holding the lower part of the front strut on..."
i can get the nuts off but can't get the bolts out, any advise? please help soon!
Old 07-13-2008, 10:59 AM
omgshesaboy's Avatar
hammer.. or search button this has been discussed
Old 07-13-2008, 11:00 AM
Haz l33t wheelz.
ls1fbody's Avatar
hammer and a fat punch.
sn!perwolf's Avatar
Use some WD 40 or the like and hit them w/ a hammer... they pop right out
Old 07-13-2008, 11:01 AM
wbrevels's Avatar
i'll try again, i've been slamming it with a rubber mallet.
Old 07-13-2008, 11:02 AM
lewisb13's Avatar
Location: Home: Utica, MI Current Location: Mobile, Alabama
Yeah you need a real hammer. They are pressed in there. Beat the **** out of them!
Old 07-13-2008, 11:07 AM
Haz l33t wheelz.
ls1fbody's Avatar
works for most things!
rubber mallet wont do anything.. it absorbs everyhit you throw at it lol
Old 07-13-2008, 11:09 AM
lewisb13's Avatar
Its funny too because wait until he has to get the nut off on top of the strut. I can see it now, "URGENT HELP installing springs and get get mah NUT OFF!!"
cssers to the rescue. Dude beat it!! Beat it till its beat red!
Old 07-13-2008, 11:10 AM
I'm too JDM for you
BLAZIN07SS's Avatar
beat it like the bitch owes you money
Old 07-13-2008, 11:12 AM
Haz l33t wheelz.
ls1fbody's Avatar
Old 07-13-2008, 11:13 AM
sugardaddy2885's Avatar
When I first tried to get them off I was cussing and screaming I am a firm believer in the BFH (Big ******* Hammer) maneuver. Remember when putting them back in the hole and bolt both have lines on them. You can "kinda" like up the lines to make it slide in better.
Old 07-13-2008, 02:57 PM
wbrevels's Avatar
HAHA
the job is finished and it rides true< menaing i don"t need an alignment< i measured the front before and after and it dropped it 1.5" although they advertise 2" F / 2,5" rear for non SS. The actual drop from the Tenzo R GF2 springs on my cobalt was 1.5" F / 2" R and both wheel weels are equal
The rear springs creek like a bitch, any advise? i'll do some research, it sounds like the springs but could it be somehting else? THANKS FOR THE HELP GUYS!
my rtires are 215/35/18R so the wheel gap is still pretty large.
PICS(after drop)
AFTER the drop:
BEFORE the drop:
Old 07-13-2008, 03:02 PM
Tazmanian_Dvl's Avatar
Get an alignment. Just because the car doesn't pull doesn't mean you don't need to get one. You've lowered your car by 1.5"...you've just changed the telemetry of the entire suspension. Trust me it's worth 60 bucks to save your tires...
Old 07-13-2008, 03:14 PM
wbrevels's Avatar
ok man, thanks. i'll look into it
Old 07-13-2008, 03:18 PM
Haz l33t wheelz.
ls1fbody's Avatar
looks good, and as far as the drop, drive it for a week or two, then get it aligned. give your springs a chance to settle, they'll lower a bit more, and then you won't have to align it again. the creaking may be the coils rubbing together, but that should go away soon.
Old 07-13-2008, 03:24 PM
wbrevels's Avatar
get info, yea i just peeked under the car and they aren't rubbing anythingelse besides themselves at the moment, thanks for the advice man.
Old 07-13-2008, 03:46 PM
Sizzle06's Avatar
Try flipping them over,thats what i did.
Old 07-15-2008, 03:42 PM
wbrevels's Avatar
problem solved, it just took a couple hunder miles for them to stop making oise, the only reason they're squeeking is because the springs are rubbing against themselves, not any other hardware, i'll wait another week or two efore i get an alignentthanks for the hlp guys. i highly recommend Tenzo R GF2 springs for the cobalt owners, they're only $151 shipped.
10-21-2015 11:57 PM
justinchinn
10-02-2015 12:18 PM
DANRICKARD
10-01-2015 12:08 AM
Tupp
09-30-2015 08:18 PM
Dylan Johnson
09-30-2015 08:57 AM
Quick Reply: installing springs, URGENT! HELP!
