Lets talk about weight reduction again
Old Aug 25, 2015 | 04:38 PM
  #251
07blackg5's Avatar
Slobodan Milošević
I would rip it out, but I would rather not die on one random night when the windows decide they want to fog over.
Plus its a ton of work to get out, so I don't want to rip it out and find out its light. I'm sure the whole housing, coolant, and blower motor, plus all the ducts and whatever else would add up, but i wouldn't do it unless was sure if was at least 20 lbs. And sure that I could reliably keep the windshield from fogging
I mean, for shipping purposes
Old Aug 25, 2015 | 05:49 PM
  #252
Kolt's Avatar
The whole hvac box is at least 30 lbs. ive had them out at work before, they aint light.
Old Aug 25, 2015 | 10:54 PM
  #253
If serious id say keep a hair dryer and a cig outlet adapter haha
Old Aug 25, 2015 | 11:04 PM
  #254
Do you realize how much current a hair dryer uses???? Youd have to have one hell of an inverter...
Old Aug 25, 2015 | 11:07 PM
  #255
Haven07's Avatar
Look at what dodge does... My sisters caliber has a freaking 15 volt outlet in it(based on a quick google search)
Old Aug 25, 2015 | 11:38 PM
  #256
Amps not volts, are needed to determine power draw
Old Aug 26, 2015 | 09:56 AM
  #257
07blackg5's Avatar
Slobodan Milošević
my entire car runs at 15.1 volts
Old Aug 26, 2015 | 02:54 PM
  #258
Get an overpowered alternator; gonna need it anyway for the 3.5 lb battery lol
Old Aug 26, 2015 | 03:46 PM
  #259
Kolt's Avatar
There you go. run high amp alternator and inverter with electric heat. use it when you need it.
save some lbs
Old Aug 26, 2015 | 03:56 PM
  #260
07blackg5's Avatar
Slobodan Milošević
I already have a big boy alternator, remember
Old Aug 27, 2015 | 10:08 PM
  #261
Terminator2's Avatar
FWIW often times manual window setups outweigh power window setups (seats are a different story)
Old Aug 27, 2015 | 10:58 PM
  #262
nathan112i's Avatar
that high amp alternator is going to draw some serious horseponies if you were to say set up a simple hairdryer to defog the windows it would be roughly 1600w drawing 100+Amps, thats going to cost you a little over 2 horsepower
Old Aug 27, 2015 | 11:03 PM
  #263
Thats not what 07blackg5 wants to hear lol
Look this ones even advertised as a defroster lol
http://www.amazon.com/RoadPro-RPSC-818-Defroster-Folding-Handle/dp/B000BHQ5JC
Old Aug 28, 2015 | 07:06 AM
  #264
1600W does not pull 100+ amps, most space heaters only pull 15amps for 1500W. The few little economy defrosters I looked at are only 150W heaters so max a 5amp draw
Old Aug 28, 2015 | 07:09 AM
  #265
http://www.amazon.com/RoadPro-RPSC-8.../dp/B000BHQ5JC
Damn that one has a 15amp draw, better make sure the fuse is large enough for that slot
Old Aug 28, 2015 | 07:34 AM
  #266
nathan112i's Avatar
they will if you are using a 12v system like a car
14voltsx114.28Amps=1500watts
Old Aug 28, 2015 | 09:03 AM
  #267
But we all know using DC for this purpose is ludicrous
Old Aug 28, 2015 | 07:43 PM
  #268
nathan112i's Avatar
oh it would be, it was proposed that a 42volt system should be the standard for cars instead of the 12v we have. think about it you could save all that extra parasitic drag, make more space available in the engine bay by using an electric water pump,electric compressor for A/C, electric power steering pump.
RaginChopsuey
Oct 27, 2015 01:27 PM
Cptnslo
Sep 24, 2015 09:32 AM
Builttss
Sep 22, 2015 12:42 AM
breds2k
19
Sep 21, 2015 10:24 AM
