Looking for a certain thread
Old May 29, 2014 | 08:20 AM
Nathan141's Avatar
Looking for a thread on how to install #60 injectors would prefer pics.. No big deal of there ain't. I'm having trouble finding a thread with it.
Old May 29, 2014 | 08:21 AM
blueLNFftw's Avatar
On a 2.4 N/A?
Old May 29, 2014 | 09:01 AM
Nathan141's Avatar
Yes man
Old May 29, 2014 | 09:16 AM
blueLNFftw's Avatar
Why?
Old May 29, 2014 | 09:58 AM
Staged07SS's Avatar
Administrator
Administrator
Why?
This.
Old May 29, 2014 | 10:00 AM
blueLNFftw's Avatar
This.
Moar fuel = moar power.
Old May 29, 2014 | 10:59 AM
Gotta have all that fueling capability for the nitromethane
Old May 29, 2014 | 11:09 AM
Staged07SS's Avatar
Administrator
Administrator
Op, to answer your question, it is very simple to install the injectors (although not sure why you need 60's).
- Release fuel pressure by removing fuel pump fuse, and idle the car until it dies out.
- Remove fuel line from the fuel rail.
- Firmly pull the fuel rail up and out. The injectors and fuel rail will pop right out.
- Remove injector retaining clips to remove the injectors from the fuel rail.
- Install is reverse of removal.
Make sure to place some vaseline on the injector o-rings, and injector insulator seals before reinstalling.
Old May 29, 2014 | 03:34 PM
Nathan141's Avatar
Kinda thought 69's would be better. Or would 33's or 39's be a better option where it's a na..... Can't afford a to kit tell next summer anyways, gotta about 1500 to spend on the car now
Old May 29, 2014 | 03:45 PM
gibsonj4's Avatar
Why do you need #60 injectors for an NA car?
Unless you're maxing out your injectors there is no reason to go larger. Which I'm fairly certain the 2.4 doesn't run out of fuel if NA on the stock injectors. Save your 1500 towards a boost application don't just waste it, if your going to go supercharged then you can get a header and dp combo that wouldn't be wasting money
Old May 30, 2014 | 12:36 AM
andrewcarr1993's Avatar
I think he's saying he wants to be FI next year and get a few things now. You should know though OP you need a tune for bigger injectors, just wait to install them if you go with FI.
Old May 30, 2014 | 07:10 AM
Staged07SS's Avatar
Administrator
Administrator
60's are great for boosted cars, but wait to install them until you get everything you need.
No point in running them while N/A.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Builttss
Oct 4, 2015 10:21 AM
riceburner
Oct 2, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
