oil change interval v.s mileage
Old Aug 23, 2011 | 10:26 PM
weakyota91's Avatar
i know this has been a long time discussion over many forums and asked different ways sorry if its a repeat, i dont drive nearly as much as i use to (maybe 8k miles a year) i use mobile 5w-30 and a factory oil filter. my main question is about my oil filter and whats it doing over time. i totally belive in the 6 month syn oil change interval or even higher mileage but as long as i can rack up the miles in 6 months. currently i did my last oil chnage dec 4th and have only driven 4500 miles im sure the oil is ok but im worried the filter may not filter be 100% up to par i may start changing the filter every 3k miles and do oil every 6k miles as long as continue to drive this little. Does the oil life monitior actually "record/keep track of" cold starts, intown driving, driving habits such as reving stop and go and long idol periods in traffic? I know a 5$ dollar filter every 6-8 months would pretty much answer my question here just wanted some of your opinions also thanks?
Old Aug 23, 2011 | 10:46 PM
LS2SS's Avatar
i believe the oil life monitor just reads by how long your care is on bc last year i drove 2k and it was down to 25% so idk could just be my car
Old Aug 23, 2011 | 10:51 PM
sick_tight's Avatar
i go every 5k but im fully synthetic. idk about you. youre "good" til 10k or more says the oil manufacturers but i say 5k.
Old Aug 23, 2011 | 11:01 PM
bamaboy22's Avatar
I tested this on someone else's car recently. The oil went 14k miles before the oil life reminder was at 5%. It's build off how many times the cams turn and habits and a bunch of **** that goes into it. Basically if it says 0 change it. If you still have 5% the engine goes boom gm will still cover it cause your still within limits. But also keep in mind this is an oil life "reminder" not a always go by me bs. Mainly for women just like tire pressure sensors. Woman can't reset either so they get annoyed and take it in. Most should I say
LS2SS's Avatar
^Ya im full synthetic also i change around 4-5k
Old Aug 23, 2011 | 11:03 PM
nhanson's Avatar
oil life monitor tracks temperature and RPMs
Old Aug 23, 2011 | 11:05 PM
trey ss's Avatar
i change mine with mobile 1 around every 5k, is there any oil better for the car? or is mobile 1 all it should ever need?
Old Aug 23, 2011 | 11:07 PM
bamaboy22's Avatar
Don't ask that cause you will cause all sorts of stuff on here and it won't be good
Old Aug 23, 2011 | 11:08 PM
Vander Nars's Avatar
i changed mine every 10, i thought most people change regular oil every 4k nowadays so i dont know why someone would change synthetic oil at 5k
Old Aug 23, 2011 | 11:19 PM
sick_tight's Avatar
5k because it lasts me a good long while because i dont drive it all that often so its good to get the old oil out.
and I use Royal Purple... Mobil 1 is also fantastic. NOT STARTING that one here!
if you really want to know EVERYTHING about oil go to bobistheoilguy.com
Old Aug 23, 2011 | 11:21 PM
bamaboy22's Avatar
Have y'all ever wondered why they put 5k or 3 months? Think about it the oil at the store doesn't have expiration dates on the bottles
Old Aug 24, 2011 | 04:23 PM
06cobalt racer's Avatar
because when u open the bottle and put it in your car it is exposed to moisture and other things
Old Aug 24, 2011 | 10:41 PM
stonny9's Avatar
Gm and mobil 1 state the oil should be changed at least time a year no matter how little you drive
Old Aug 24, 2011 | 10:43 PM
bamaboy22's Avatar
U mean at least 1 time
Old Aug 26, 2011 | 01:44 AM
MS3 2 SSTC's Avatar
Mobile 1 Full Synthetic 5w-30 every 6K miles. Pretty much when he oil life indicator hits 25%
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
roth
Sep 26, 2015 12:16 PM
