Oil Change: Jacks and Jackstands VS. Ramps?
Old Sep 15, 2006 | 03:48 PM
JonyyB's Avatar
Site Founder
I always wanted a set of ramps. It is so much easier to drive your car up the ramps and do your thing.
What do you guys use for the Cobalt? Ramps or Jack and stands?
Old Sep 15, 2006 | 03:49 PM
roccityroller's Avatar
Jackstands...they're all i have...and it's not THAT much harder...lazy
Old Sep 15, 2006 | 03:54 PM
KillerNutz's Avatar
I use jackstands, the ramps that I have, I cant get the car onto without a lot of effort, so its just easier to jack it up and throw the stands under it.
Old Sep 15, 2006 | 03:55 PM
Tomtwtwtw's Avatar
Ramps give you a lot more breathing room under the car, and for me at least, it's much quicker. Just don't go up them too fast...
Old Sep 15, 2006 | 04:18 PM
marerick007's Avatar
Ramps can be a problem sometimes....I personally don't like them. They almost always move when you try to get on them, unless you can keep them somehow. With the front being so low, you might actually damage it. Never tried it so I don't know...Jackstands and a small roller jack will do you wonders, plus when it comes to rotating tires, you can't do it with ramps, LOL!
Old Sep 15, 2006 | 04:29 PM
uthinkimodd's Avatar
ramps are good for oil changes and that's about it when it comes to our cars. jacks and stands give you the ability to take the wheels off giving you access to everything.
Old Sep 15, 2006 | 04:47 PM
Tomtwtwtw's Avatar
I have both ramps and stands, but my jack sucks. It's lost a couple inches of lift over the years...if you get the basic rhino ramps, your car should be fine. I have less than 1/4" of clearance between my front lip and the top of the ramp going up, but there *is* clearance - that's the key.
Just don't back down it in a hurry and there's nothing to worry about. Also, I'm not sure if all ramps have them, but mine have rubber stoppers on the underside of the front to keep them from slipping while going up or down. They don't move an inch on concrete or asphalt.
Old Sep 15, 2006 | 04:56 PM
bouncertime's Avatar
I just use a four post car lift.
Old Sep 15, 2006 | 07:47 PM
css9450's Avatar
For an oil change? I just reach under there to get the drain plug. Sure its a stretch but not unreasonable. The filter is up on top so that means less time reaching under the car.
I have a floor jack and stands if I need more clearance for other work.
Old Sep 15, 2006 | 07:59 PM
zinner's Avatar
Moderator Alumni
jack stands.
The oil filter is a BITCH. It's this giant size nut (1.5 inch I think) and you need a 1/2 drive and universal joint for it.
Old Sep 15, 2006 | 08:33 PM
css9450's Avatar
Originally Posted by zinner
jack stands.
Old Sep 15, 2006 | 11:01 PM
plyboy-illest's Avatar
use a jack and jack stands here...
Old Sep 15, 2006 | 11:23 PM
CobaltSS422's Avatar
i use jack stands and i am VERY VERY afraid to use the ramps.. although i would love to use the ramps but i'm on sportlines and i don't think my car would be successful at driving up those things
Old Sep 15, 2006 | 11:29 PM
joeworkstoohard's Avatar
they do make low-pro ramps... they're only like six-eight inches tall for low cars. personally, i HATE jacking up cars, and use ramps whenever i can. the hardest part with a ramp is telling yourself that you're not going to go over the other side. (it's even harder with a 5 speed because if you stop, it's a royal bitch to go SLOWLY up.
with that said, i just reach under.
Old Sep 15, 2006 | 11:30 PM
SpecialK's Avatar
Jack and stands. It's a bitch though with my CRX, damn thign sits to low so Iactually have to use a set of 2X4s to get my jack under it. I really shoudl adjust these coilovers.
Old Sep 15, 2006 | 11:33 PM
these are too much money, but you get the idea.
http://www.discountramps.com/low_profile_car_ramp.htm
Old Sep 15, 2006 | 11:56 PM
WOW, yeah just a tad too much! Those things better keep beer cold and wax the car for that price!
Old Sep 16, 2006 | 12:45 AM
djpatrick35's Avatar
I use jackstands...
Old Sep 16, 2006 | 09:09 AM
toydriver00's Avatar
jack stands.
It is a 32mm. I got one that uses a 3/8 ratchet and extension.
I use ramps for the oil change, and stands for everything else.
Old Sep 16, 2006 | 01:12 PM
redSSBalt's Avatar
I also use ramps for the oil changes. It's so much easier, just line them up and pull right up them.
Old Sep 16, 2006 | 06:57 PM
SilverSS/SC's Avatar
For a oil change , I use ramps . My rhino ramps jus barely clear the lower lip .
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
