Pulstar Pulse Plugs!!!
Old Feb 7, 2008 | 05:46 PM
creepySS's Avatar
I was wondering if anybody are using these ? here is the linkhttp://www.pulstarpulseplugs.com/default.asp
Old Feb 7, 2008 | 05:51 PM
Nuclear's Avatar
looks interesting!
Old Feb 7, 2008 | 05:53 PM
BLKblurr06's Avatar
these have already been discussed, interesting as they are you cannot use them in an SS/SC
Old Feb 7, 2008 | 06:02 PM
Onyxd04Redline's Avatar
Stay with Copper's
Old Feb 7, 2008 | 08:56 PM
creepySS's Avatar
the test are being done in a srt-4 so is a forced induction engine whats is the the difference with ours?
Old Feb 8, 2008 | 05:32 PM
BLKblurr06's Avatar
well last discussion on these plugs included that these werent available in the propper heat range that would be safe for forced induction...Perhaps now they are developing plugs designed for boosted cars, not sure about them though
Old Feb 8, 2008 | 05:36 PM
EdCobaltSS's Avatar
Originally Posted by Onyxd04Redline
Stay with Copper's
X2 I WOULDNT RUN ANYTHING BUT COPPER... MOST BANG LEAST BUCK
Old Mar 23, 2008 | 08:59 PM
xtrmsnd's Avatar
Are you guys ruling this out without reading all the facts about this.
http://www.pulstarplug.com/images/EnerpulsePopSciAd.pdf popular science review
Old Mar 24, 2008 | 12:12 AM
CobaltCoupeCrazy's Avatar
REPOST
There is already a thread for these.
Old Mar 24, 2008 | 12:15 AM
Mnatvyc1223's Avatar
please elaborate? both copper and iridium offer different advantages, but y do you think these are better than the iridiums???
Old Mar 24, 2008 | 07:16 AM
EdCobaltSS's Avatar
iridiums will just last longer, but the coppers give you a better controled spark. iridiums will give you a better spark than platinum, but not as good as copper. only downfall to copper is they should be changed every 10,000 miles. i usually change mine every second oil change. And for 1.50 per plug, its not too big of an expense.
Old Mar 24, 2008 | 09:36 PM
selfinfliction's Avatar
pulstar won't work in more than stock ss/sc. colder plugs would require that sparkplug adapter thing they sell from pulstar and those won't fit on an ss/sc because of the coil on plug design. the coils would sit up too high and the bolt wouldn't fit to secure them
Old Mar 24, 2008 | 09:49 PM
ifknrock09's Avatar
i called pulstar and they told me that they make plugs for our cars. so that tells me that they would fit. and as for the copper= most bang. not true. if you do your research on these plugs they have what is similar to a capasitor that builds energy and releases it. when it releases its more than twice the bang. now whether they are cooler plugs or not i don't know. i didn't ask. but i will be looking into it.
Old Mar 24, 2008 | 09:54 PM
tkaugh29's Avatar
i have ngk bkr7e ix iridiums and couldnt be happier
Old Mar 24, 2008 | 09:57 PM
yeah they make them that will fit stock, don't run these plugs if you're putting them on a modified car.
Old Mar 24, 2008 | 11:19 PM
LopsidedJester's Avatar
i think a point was copper= more bang for buck. I've seen dyno results, and there was maybe an average of 2-3 hp difference at the end, and iridiums vs. pulstar was about an average of .5hp difference, but it seemed pretty flawed since the average hp range was about (+-) 6-12 hp from test to test with 3 tests for each different plug. Too much margin of error for concrete results.
The tests just don't justify it, i think if they did twice as many tests and one with another car then results might stick better. With a MPG test, maybe it'll give you slightly better burn and more efficiency (remember the words maybe and slightly), but a spark is a spark and the burn propagation and AFR is what matters after that.
As long as you have a proper gap and a good working plug (of your choice copper, iridium, titanium, or pulstar if you have the urge), i doubt you'll see a difference in performance and i'm sure you'll be wishing you hadn't spent $100 on freaking spark plugs.
Old Mar 25, 2008 | 01:06 AM
xtrmsnd's Avatar
i just ordered mine today after talking with a tech from the company. He said in no way will these spark plugs do any harm to my car and that he stands behind the product 100%I'l you guys know how good his word is friday
Old Mar 25, 2008 | 07:05 AM
yeah but if you're modified and you start blowing out the spark cause of the hot plugs, you engine bearings and other internals won't love you anymore
hope they work out for you
Old Mar 25, 2008 | 07:47 AM
mmmrodge's Avatar
not trying to highjack thread but what does everyone else use for plugs?
Old Mar 25, 2008 | 08:10 AM
djt81185's Avatar
There is charge only applied to the plugs when the ecm wants them to fire...there is no constant feed to them to "charge the capacitor" If it charges then sparks its actually delaying the spark from when the ecm actually wants it to fire
Old Mar 25, 2008 | 08:17 AM
SK360's Avatar
omg so many 18yo engineers here....
This is the silliest marketing scheme I have ever seen....
I urge you to continue to waste your money, please, it will extend the LAWLS
Old Mar 25, 2008 | 08:35 AM
ifknrock09's Avatar
thats why its called technology. it is getting a little more advanced everyday.
Old Mar 25, 2008 | 08:40 AM
SK360's Avatar
Lulz... Do you have any idea how sparkplugs work? from the PCM to the Coil pack to the Plug?
If the answer is yes, do you understand how capacitors work?
If the answer is no to any of the above, then please educate yourself.
If the answer is yes to both, well, you ******* lied, see above solution.
Old Mar 25, 2008 | 08:42 AM
ifknrock09's Avatar
and not to sound like a dick but you probably shouldn't judge people that you don't even know. all that i did was read about them and even went a step further and called them. its not a marketing scheme. almost every apliance in your house has a capasitor. and thats what this is. just a little bit more advanced. but you probably wouldn't understand that. i mean why would you. i'm just a 23yo that probably has a little more experience with **** like that. but hey i do agree with the other people that if they aren't cooler plugs then its a bad idea for a modded cobalt.
Old Mar 25, 2008 | 08:45 AM
djt81185's Avatar
See Sk360s post for my feelings
