SS S/C or Turbo 2.2L
Old May 19, 2005 | 03:04 AM
Vendian's Avatar
So what's going to be faster....any guesses? By the way here is the thread for the Turbo 2.2L:
Thread, and here is the turbo.
Old May 19, 2005 | 06:51 AM
frankmckeever's Avatar
This should run the 2.2L Ecotec a little bit faster than the SS. That's what we're hoping for at least!
Thanks for your interest.
Old May 19, 2005 | 08:56 AM
3fo893013L's Avatar
I would like to see both a 2.4L Turbo and 2.4L S/C. Turbo will have more potential though.
Old May 19, 2005 | 09:18 AM
jzchev28's Avatar
ummmmm.....only one way to find out
Old May 19, 2005 | 09:23 AM
plyboy-illest's Avatar
i would think it would make it as fats or faster depending ... but im sure if you thorw one of those in ur vid your warenty..
Old May 19, 2005 | 02:59 PM
MarcS's Avatar
The Stig
The SS S/C was pre-built up for forced induction. It also has a better suspension, and the getrag tranny. I'd still prefer the 2.0L S/C. An intercooled T3 turbo on the 2.2L Should make around 220hp ballpark. I would say the turbo has the hp advantage, but with some tweeking... the 2.0L SC can easily make more power and will still perform better on the turns.
I checked a few sources and the SS S/C makes 217hp(NOT 205) at the wheels with premium fuel. Throw in a high flow drop in filter and it produces around 220hp.
I agree however that turbo has more potential. After all, it produces boost from a byproduct, whereas a supercharger has to be cranked. I do think that a well built turbo 2.2L with other suitable performance parts could give a stock SS S/C a good spanking. However, I beleive a well built SS S/C can run toe to toe with an STI. (Hopeful thinking)
Old May 19, 2005 | 03:19 PM
MarcS's Avatar
The Stig
Wow.. props to the LS, theres already a 12 second Cobalt.
https://www.cobaltss.net/forums/general-cobalt-68/kindle-racing-cobalt-ls-pictures-drag-forum-2018/
Old May 19, 2005 | 08:20 PM
Florida 76's Avatar
turbos have to be cooled down after driving..... witch means you need a turbo timer that leaves the car running 10 minutes after you get out......if you dont have one you will screw up you engine and turbo..... i will stick to a supercharger there much more reliable..
___________
Old May 19, 2005 | 10:09 PM
That's actually only suggested to do if you are doing agressive. The typical cool-down time is anywhere from 3 - 6 minutes...but hey, you can always sit in the car after racing someone
Old May 19, 2005 | 11:04 PM
Vendian's Avatar
You brought up interesting points with the suspension mods. The cost would be about the same, but my guess is that the 2.2L will not hold it's own in a turn compared to the SS. I think I'll stick with an SS.
Old May 20, 2005 | 11:08 AM
You could always go with a nice setup of Koni Struts and Eibach Sportline Springs...and then hit it off with some sway bars and strut bars
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
maliki778
Oct 1, 2015 07:39 PM
