Turbo 2.4 automatic fully installed! PICS...
Just wanted to drop in and say congratulations celicacobalt! It must be nice to finally see your turbo dreams come to life. Can't wait for the dyno and track numbers.
As for those who say SS/SC guys are going to be jealous, I have to agree with Ryuu600, they should be PROUD of their Cobalt brethren. I know I am!
42's are capable of more power than we are getting out of them. The problem is the high boost levels "shrinking" them. 42's should be fine for the 2.4 running 10.4:1 compression and lower boost. I bet he will put out more power with the 42's than a 2.0 will on the stock fuel system.
Think about what u just said...ss/sc has a 32.5lb/hr ish stock injector...id hope hed make more hp then a stock ss/sc when his injectors are almost 20% larger.
His injectors will be good for roughly 250whp on the dyno he is dynoing on
just imo tho
Yeah, but your numbers will be real, not just ego boosters. It will be best if you can dyno on the same one you got your previous baseline reading on. If not, just remember your corrected numbers can easily vary 5-6% between dynos of the same make.
Don't worry, your injectors will do fine. I don't think they will go static on 8-10lbs.
link to new thread here ******$$$$$$######
https://www.cobaltss.net/forums/pictures-videos-64/turbo-2-4-up-running-but-not-great-video-inside-53460/
