What's a 'weak' engine?
Old Dec 21, 2017 | 10:57 PM
OhSixBalt's Avatar
Hi there I was talking to a mechanic and he said there's no point having a Stage 2 ZZP pully/ECU upgrade on a 'weak' engine.
What the heck?
Ok I understand an engine is only as strong as the weakest link, so bad rings, worn engine, 300K miles on the engine, I get it, weak engine and probably not worth hooking up a smaller pully and more power because it's on it's last legs. I could see weak meaning less horsepower because of worn engine surfaces like cylinders, or rings or crank and so forth.
But I still don't know what 'weak' engine means when there's some, but not a lot, of road distance.
Is 128,000 kilometers on an engine too many kms to consider a Stage 2 upgrade for the SS/SC? 3.1 pully, etc.
Or will I require a compression test?
Thanks
Old Dec 22, 2017 | 01:14 AM
Sharkey's Avatar
128k km is nothing, especially for an unmodded ecotec. im at 230k km on my ss/sc and its had at the largest a 2.8" pulley (and supporting mods) since it had 20k on it and its still going strong.
Old Dec 22, 2017 | 08:13 AM
jdbaugh1's Avatar
Yeah a simple compression test would generally let you know how "weak" your engine is. Like sharkey said 128k is nothing.
Old Dec 22, 2017 | 09:27 AM
Kolt's Avatar
Compression and leak down test will show how "healthy" or "weak". your engine is, 128km? that's only 80k miles. So long as its been taken care of its still in its prime for modding.
Old Dec 22, 2017 | 09:32 AM
Your car has low miles considering the age, crank it up.
Old Dec 26, 2017 | 11:46 AM
06blackg85ss's Avatar
I was making over 500whp on a stock bottom end with 175k miles on it.
maintain with oil changes and these motors don't "age"
(pulled that motor out with 206k miles on it and it still had crosshatches on the cylinder walls).
Old Dec 29, 2017 | 07:01 PM
Flarfignewton's Avatar
Do a compression test and make sure nothing is mechanically wrong or leaking. As long as everything checks out, you're fine. I have 143k miles on mine with stage 3 and I still have compression numbers in the 180-200 range.
Old Jan 2, 2018 | 10:23 AM
06blackbalt's Avatar
Just send it
Old Jan 2, 2018 | 10:45 AM
Originally Posted by 06blackbalt
Just send it
qfe
Old Jan 2, 2018 | 11:32 PM
Bluelightning's Avatar
Got Bewst?
Listen to this guy. He knows how to send it.
Old Jan 3, 2018 | 06:42 AM
jmix's Avatar
My car was stock power level until 156k miles and then I pullied down, tune, etc. Knock on wood, it's at 169k and still running strong.
Old Jan 3, 2018 | 09:27 AM
umrdyldo's Avatar
Stage 2 plus cooling mods and your engine will go for 200,000 miles without blinking.
One thing people don't do enough of is monitoring and logging. You need to know the moment your IC pump fails and when other things go wrong. Get ahead of maintenance on the car and change the oil with great oil often and it will do well.
Old Jan 3, 2018 | 10:45 AM
jdbaugh1's Avatar
I agree with this big time. I think people let little issues go way too long and don't do anything about them until they turn into much bigger issue which could have been avoided. Like driving with the check engine light on and not even caring what it is for because the car appears to be running fine.
Old Jan 3, 2018 | 10:48 AM
exninja's Avatar
Ha! I try to give facebookers crap every time they post "what's wrong with my car???" and their CEL is on.
Old Jan 3, 2018 | 10:53 AM
user 72239's Avatar
the only weak engine is the engine that isn't tuned correctly or not taken care of.
everything has its limits however.
Old Jan 3, 2018 | 03:00 PM
steelmesh's Avatar
One thing I can think of that will go weak in an engine would be some loss of valve spring load (load loss, relaxation). Short shift then problem solved!
Old Jan 3, 2018 | 11:34 PM
cluelessk's Avatar
Some cars start to show issues related to the porous block problem early LNF's had at higher miles.
007G5GT
45
Jun 25, 2009 07:14 PM
Ljavy17
Sep 29, 2006 09:57 AM
Ardskoay
Jun 18, 2006 07:03 PM
ninja44
Drag Racing
52
Jun 17, 2006 01:45 AM
06G5GT
Apr 10, 2006 04:57 PM
