2.2 LAP Engine: 2.4 Intake Manifold install on 2008 2.2
Old Feb 2, 2010 | 05:52 AM
  #51
bigdogstokes16's Avatar
nice write up maven, deffinately will be using this when i get mine, i have two little snags, should i buy the mani kit from Crateenginedepot it will be 250 bucks and some change and all neccessary hardware will come with it, i found the H/O mani from zzp for alot cheaper around 160.00, im pretty sure its the exact same kit but it seems like it doesnt come with all the extra stuff ill need, does anyone know if the zzp comes with all the neccessary hardware for me to install on my 07'?? sry for the long post lol
Old Feb 3, 2010 | 02:50 AM
  #52
nobody?? anyone??
Old Feb 3, 2010 | 03:44 AM
  #53
unijabnx2000's Avatar
buy it, find out, then you tell us
Old Feb 3, 2010 | 02:19 PM
  #54
whyyoumadson?'s Avatar
you dont need the adapter plate that comes with the CED kit for an 07. Only the 05/06 cars use it. So the ZZP kit might be a great deal. You just need the gaskets.
Old Feb 4, 2010 | 05:07 AM
  #55
ok thanx guys looks like ill be getting the zzp one cheaper and hope for the best, let you guys know how that works out
Old Feb 14, 2010 | 03:05 AM
  #56
09cobylt's Avatar
Question: Idk if any one asked this but what does this do for the 2.2L, also do all the gaskets and stuff come with it so you dont have to buy from GM, thanx
Mike
Old Feb 18, 2010 | 12:02 AM
  #57
Mregan's Avatar
Well what do you think? Now you have a 2.4 manifold instead of a 2.2 = more power, but less torque at lower rpms
Old Feb 26, 2010 | 04:33 AM
  #58
i just got the zzp kit but i diddnt order the gaskets with it, all my original seals worked fine but i noticed AFTER i put it on on that i diddnt have the crankcase passage seal, started it up and it ran bad, so is the CPS absoblutely neccessary??
Old Feb 26, 2010 | 03:18 PM
  #59
hellooo?? somebodys gotta kno
the cars not running and i have places to go, is the crankshaft passage seal a solid gasket where i can just plug the hole and go without till monday or does it have holes in the gasket seal?
Last edited by bigdogstokes16; Feb 26, 2010 at 03:18 PM. Reason: Automerged Doublepost
Old Mar 4, 2010 | 11:06 AM
  #60
06C0BALT's Avatar
just kinda wondering how much this entire 'kit' costs?
Old Mar 14, 2010 | 08:02 PM
  #61
ilovecars's Avatar
its got a tiny little hole in the center of it you really need the one for the 2.4 manifold.
Old Mar 22, 2010 | 01:52 PM
  #62
09cobylt's Avatar
does this work on 09 2.2l???
Mike
Old Mar 27, 2010 | 01:06 AM
  #63
dskav's Avatar
Originally Posted by warrenb213
The 07's DO NOT require an adapter plate for the 2.4 mani.
Well I have an '05 so I will need the adapter plate but there's no way that piece alone is worth the extra $80 at CED vs. ZZP. Does anyone know where to find this adapter plate? Is this it?
http://www.crateenginedepot.com/stor...P1820C137.aspx
Old Mar 29, 2010 | 07:44 PM
  #64
conerboner's Avatar
sub'd, great writeup
Old Mar 29, 2010 | 10:22 PM
  #65
INTENSEL61's Avatar
I am installing my 2.4l intake mani now. I am having a hard time removing the brake booster hose. The how-to states to remove the brake booster hose from the "power brake booster". I suppose the power brake booster is when the brake booster hose ends (in the firewall?). I tried pulling the hose in a downward motion after removing the black clip lock but it isn't coming off whatsover. Any suggestions?
Old Mar 30, 2010 | 10:42 AM
  #66
INTENSEL61's Avatar
Anyone?
Old Mar 30, 2010 | 02:08 PM
  #67
dskav's Avatar
any help on this??
Old Apr 9, 2010 | 05:32 PM
  #68
ebolt123's Avatar
I got the 2.4 intake and the gaskets with it. the crankcase passage seal did not come with it. Do you know the part number or where i can fine one?
Old Apr 28, 2010 | 09:45 PM
  #69
LEXXONE74's Avatar
Same Problem Here.
Bought mine from ZZP-Performance got extra seals/Gaskets except for the crankcase one & now my car sounds like I have the "HORN" pressed down so I'm Making my own with a peace of rubber tubing.
Old Apr 29, 2010 | 06:43 PM
  #70
LEXXONE74's Avatar
The odd looking seal between ports 2 and 3 is called a 'PCV SEAL'. PART# 12589516 at $9.46
Old May 6, 2010 | 05:11 PM
  #71
royce777's Avatar
does this work on 09 G5 GT?
Old May 7, 2010 | 09:02 PM
  #72
conerboner's Avatar
isn't the g5 GT a 2.4?
Old May 9, 2010 | 01:05 PM
  #73
08ShowbaltLS's Avatar
do i need to order the 06-07 manifold or the 08+ one?
they are different prices on crateenginedepot
Old May 14, 2010 | 02:36 PM
  #74
if i get the zzp kit do i need to get the gaskets or can i reuse mine???
Old May 14, 2010 | 02:43 PM
  #75
conerboner's Avatar
will one from on 08 work on an 07?
